Jeep Just Died during driving and will not re-start #790571 02/18/07 10:36 PM
josephelk Offline OP
My problem went to the next level. I was driving last night and it just died. It still turns over but IÆm getting no spark? I replaced the Coil thinking that was it but I still do not get spark through the coil. All the Jeep does is turn over like the coil wire is disconnected?
89 YJ, 3.5" Black Diamond Lift, 33" tires, 8000lb Warn, 4.0 91 XY engine swap.
Re: Jeep Just Died during driving and will not re-start [Re: josephelk] #790572 02/19/07 12:20 AM
BigJim Offline
Prolly the sparkbox under the wiper fluid container... could be the PICKUP in the dist.
OHHHH now I see the 4.0! Yikes! How bout the cps?
Re: Jeep Just Died during driving and will not re-start [Re: BigJim] #790573 02/19/07 12:26 AM
What is a sparkbox? Would I still get spark from my coil if it had anything to do with the distributor?
Re: Jeep Just Died during driving and will not re-start [Re: josephelk] #790574 02/19/07 01:12 AM
CLARK Offline
What year. Does it have fuel injection , the Crank POSITION sensor at the rear of the crank will cause a no spark
Re: Jeep Just Died during driving and will not re-start [Re: CLARK] #790575 02/20/07 04:20 AM
It was a 30AMP fuse for the engine controller. Was that what you meant BigJim when you mentioned the sparkbox?
I had the 4.2L that was in my Wrangler originally all figured out so now I get to figure out all the little problems with the 4.0L, still no regrets with the 4.0. I have gained 7 miles per gallon and about 70HP with swapping the two engines.
Thanks for all the help.
Josephelk
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6056 MB (Peak: 0.6693 MB) Data Comp: Off Server Time: 2026-06-23 11:15:40 UTC
