Engine Noise Question #790589 02/19/07 01:22 AM
Kotrin Offline OP
I noticed recently that when my jeep is under a load it sounds like it's missfiring when I try to accelerate quickly. It sounds like my lifters (i think it's this) is clicking. It sounded at first like an exhaust leak but it only does it when i'm driving and I really try to accelerate. Doesn't do it when it's just sitting still though and I rev the engine. How can I fix this, or does it need to be adjusted is all? Any help is apperciated, thanks.
- Kotrin
Re: Engine Noise Question [Re: Kotrin] #790590 02/19/07 02:50 AM
BigJim Offline
It would be nice to know what we are working on.
Re: Engine Noise Question [Re: BigJim] #790591 02/19/07 03:03 AM
Kotrin Offline OP
Doh, been a long weekend. It's a 98 TJ Wrangler 4.0L with 70k miles on it. It's had regular oil changes and fluids recently changed.
- Kotrin
Re: Engine Noise Question [Re: Kotrin] #790592 02/19/07 08:00 AM
BobRowe Offline
I'd do a quick check on the timing first, in particular the advance settings.
Re: Engine Noise Question [Re: BobRowe] #790593 02/19/07 07:15 PM
cjensen Offline
Take a quick looksy at the head and the manifold and exaust.
jmho
C.
Re: Engine Noise Question [Re: cjensen] #790594 02/20/07 03:25 AM
Kotrin Offline OP
jmho
C.
What should I be looking for. I've felt for a leak and didn't feel one and it's wierd if it's sitting I rev it up and I dont hear it, only when i'm driving <img src="/forums/images/graemlins/frown.gif" alt="" />
- Kotrin
Re: Engine Noise Question [Re: Kotrin] #790595 02/21/07 04:42 PM
bhartwell59 Offline
sounds to me that we have the same issue... except mine is with my 1-year old mopar fuel injection kit on an '87 4.2.
in my case, under heavy acceleration, there seems to be a "chatter" noise @2100+ rpms. worked on the timing and i still have the noise. i know it has to be from the engine/mopar kit because it wasn't there prior to the kit installation.
i'm still trying to narrow this noise down.
4.2 '87 yj, 263,000 miles, mopar mpi, 33" mud bfg, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 shaft conversion, tom wood's hd driveshaft, magnaflow/custom exhaust, 4wd bumper/swing-out tire carrier
Re: Engine Noise Question [Re: bhartwell59] #790596 02/21/07 05:18 PM
BigJim Offline
You guys do know that injectors do make a noise everytime they close? I betcha you are hearing injector noise and worrying about it. My wifes suburban clicks so loud you'd swear it was lifters. But it is just the injectors doing their job.
Re: Engine Noise Question [Re: BigJim] #790597 02/22/07 04:02 PM
bhartwell59 Offline
ok, but wouldn't that happen all of the time? at idle and normal driving?
in my case, the noise makes quite a racket, at the 2100+ rpm point.
i'm stomped.
Re: Engine Noise Question [Re: bhartwell59] #790598 02/22/07 04:28 PM
BigJim Offline
Well it could be valve clatter. Put a light on it and slowly raise the rpm while watching the timing change. See when the centrifical and when the vacuum timing comes in and what the timing is around the 2100 mark. Could be you need a different set of springs or some spring dialed into the vac advance.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6354 MB (Peak: 0.7581 MB) Data Comp: Off Server Time: 2026-06-21 12:19:41 UTC
