FXJ80 third swap q's #790771 02/19/07 05:36 PM
bnold Offline OP
I know this has been asked and discussed a million times, but I'm going to throw it out there again. I have an 85 pickup, my step pappy has a 97 LX450 (FZJ80) and we are getting ready to sell. 212,000 miles needs a new home. I have heard and read a lot about using the electric lockers in pickups like mine... I hear there are modifications required to fit the fzj third into my axle... OK so if I did the modification and put the third in my truck could I put my stock thrid back into the FZJ?? In order to make it run and sell it again? Minus lockers of course.
Also I have read alot about using the front, but not the rear?? Is it swappable for anything?
Thanks
Re: FXJ80 third swap q's [Re: bnold] #790772 02/19/07 05:40 PM
4Crawler Offline
More work to do as you have to fill in the notch in the mounting flange (the one you cut one on the install) and then drill and tap some holes for the mounting studs.
Re: FXJ80 third swap q's [Re: 4Crawler] #790773 02/19/07 05:49 PM
bnold Offline OP
How large is the 'modification' that would have to be done to my axle and undone to the FZJ axle?? not affraid of the welders and grinders... If its too much of a pain I'm not worried about it... Just a thought before the LX goes up on ebay...
Re: FXJ80 third swap q's [Re: bnold] #790774 02/19/07 05:57 PM
4Crawler Offline
Could not tell from your intial e-mail if you had already installed the e-lockers or not or even read about the installtion. If not, read this, it'll answer all your q's:
http://www.4x4wire.com/toyota/tech/electric_locker/
Re: FXJ80 third swap q's [Re: 4Crawler] #790775 02/19/07 06:30 PM
bnold Offline OP
Thanks for the response. I had not seen that yet. It looks doable to swap back and forth only problem area being replacing the larger cutout towards the botom of the picture.
Probably to much work to worry about, but its an option for a couple weeks...
Are there axle spline differences in the FZJ thrid and the stock 8"?
Thanks Again
Re: FXJ80 third swap q's [Re: bnold] #790776 02/19/07 07:12 PM
4Crawler Offline
Same splines or else the swap would not be possible.
Re: FXJ80 third swap q's [Re: 4Crawler] #790777 02/19/07 08:34 PM
ErikB Offline
Toyota Moderator
Your low-pinion diff won't work in the 80 because the steering won't clear the diff.
And I'm assuming you're only talking about the front diff anyway. The rear diff is not swappable (very different).
http://home.4x4wire.com/erik
Re: FXJ80 third swap q's [Re: ErikB] #790778 02/19/07 11:03 PM
bkg Offline
Was just going to type that. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Brian K. Gallus
Re: FXJ80 third swap q's [Re: bkg] #790779 02/19/07 11:28 PM
4Crawler Offline
Suppose you could swap in a non-e-locker high pinion diff in there, but then the cost savings on the "free" e-locker is mostly lost.
Re: FXJ80 third swap q's [Re: bnold] #790780 02/20/07 03:04 AM
jasonmt Offline
The modifications are not much either to do or undo as the case may be. Below is a factory E-Locker flange bolted up to a 4cyl open third:
As already mentioned the steering setup on a 80 requires a HP third:
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6395 MB (Peak: 0.7439 MB) Data Comp: Off Server Time: 2026-06-07 03:51:57 UTC
