leeky tacoma need help
#790786
02/19/07 06:44 PM
hey guys, Heres the deal I have re-appering water on my passenger floor board. I have looked all over the truck cant find any thing that seems like it could let the water in. I did find under the glovebox against the firewall a piece of the sound reduction foam that was wet but cant see where the water is coming from.(not from heater/ac unit, or from any of the wire gromets on the firewall.) if any body has any thoughts or knowledge from having the same prob. that would be great. Thanks for the time, Eric S.
Eric S.
2000 Tacoma -6in of lift,33x12.50 truxx's M/T's
Re: leeky tacoma need help
[Re: EDS2000tacoma]
#790787
02/19/07 07:25 PM
Check the windshield seals.
[Re: azrain]
#790788
02/19/07 07:43 PM
From what I can see the seals are ok, but could there be some way water is making its way in once it goes in the "tray" that holds that windshield wiper linkage?
Eric S.
[Re: EDS2000tacoma]
#790789
02/19/07 08:30 PM
There's all kind of drains and weep holes in through there, I would start checking those.
[Re: azrain]
#790790
02/19/07 08:45 PM
Thanks thats what I thought
Eric S.
[Re: EDS2000tacoma]
#790791
02/21/07 04:11 PM
Is it occuring during/after rain, our after you have been in water?
Are you sure your A/C is not icing up and then thawing leaving water on the floor?
1995 4Runner Limited V6 3.4 Liter 5 Speed 4x4 1995 4Runner V6 Auto 2WD
[Re: Kutter]
#790792
02/21/07 06:07 PM
it has been freakin cold so i havent ran my ac in a long time. and i know its not from the door seals, it is somthing on the firewall just cant find it.
Eric S.
[Re: EDS2000tacoma]
#790793
02/22/07 12:13 AM
Your A/C is on by default every time you use your defroster. My 2001 Taco's A/C runs even if I try to turn it off with the dash button...
[Re: Whizkidder]
#790794
02/22/07 02:24 PM
Huh. I did not know that, I guess I need to take another look at that A/C to make sure that its not the prob. thanks for the help.
Eric S.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.004s) Memory: 0.6237 MB (Peak: 0.7098 MB) Data Comp: Off Server Time: 2026-06-07 07:22:29 UTCValid HTML 5 and Valid CSS
