no 2 wheel drive on my dana 300 #790981 02/20/07 06:44 AM
hdrulz Offline OP
need a little help on this one for the last week I was driving in 4 hi ( 2 foot of snow) now the plows finally did there job and cleared the roads my transfer case wont engage the rear axle / drive shaft in 2 hi. In 4 hi only the front pulls i have the stock singlr shifter.
A Jeep, A Harley, A House, I think I have it all
Re: no 2 wheel drive on my dana 300 [Re: hdrulz] #790982 02/20/07 11:41 PM
BigJim Offline
Linkage...or do you still have a rear driveshaft under there?
Re: no 2 wheel drive on my dana 300 [Re: BigJim] #790983 02/21/07 02:40 AM
hdrulz Offline OP
drive shaft is still on un locked hubs (front) and had girlfriend run through 4low to 4hi front drive shaft moved jeep didnt ie. no power to the rear
Re: no 2 wheel drive on my dana 300 [Re: hdrulz] #790984 02/21/07 02:43 AM
Bigbird79 Offline
Did you hear any nasty grinding or metal breaking sounds while you were driving around in the snow? It sounds to me like either part of your linkage that works the rear shift fork broke or bent, or you did some serious damage to the t-case. Is it leaking?
Re: no 2 wheel drive on my dana 300 [Re: Bigbird79] #790985 02/21/07 02:44 AM
Bigbird79 Offline
what does it do in 4 low?
Re: no 2 wheel drive on my dana 300 [Re: Bigbird79] #790986 02/21/07 05:06 AM
hdrulz Offline OP
its an 82 all original CJ7 /w a 151 cid. 4 speed I swapped a black diamond 3" lift and 33 X 13.5 super swampers ( I bought it with 32's and stock springs) everything leaks but no aparent damage to the case no grinding or breaking sounds
Re: no 2 wheel drive on my dana 300 [Re: Bigbird79] #790987 02/21/07 05:10 AM
hdrulz Offline OP
front shaft spins nothing at the rear im gonna pull the case tomorrow
Re: no 2 wheel drive on my dana 300 [Re: hdrulz] #790988 02/21/07 03:04 PM
Bigbird79 Offline
I would take a real close look at your linkage before you pull it. There should be 2 shafts moving in and out of the T-case when you move the shift lever. You may have just damaged part of the linkage and are only moving the front shift fork. You may need to pull the case too, but its a lot easier to lay under the jeep and have someone shift it before you pull it.
Re: no 2 wheel drive on my dana 300 [Re: Bigbird79] #790989 02/25/07 06:51 PM
hdrulz Offline OP
both rods move in and out I eaven checked to make sure they were indixing properly (looking through the inspection cover) only the front drive shaft spins in 4 hi or low
Re: no 2 wheel drive on my dana 300 [Re: Bigbird79] #790990 03/01/07 04:31 PM
hdrulz Offline OP
I found the problem the set screw in the shift fork came loose
if Im thinking correctly in goes into what apears to be a locating hole at the end of the shift rod
PS thanks for the advice and help
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6297 MB (Peak: 0.7207 MB) Data Comp: Off Server Time: 2026-07-16 03:25:44 UTC
