no 2 wheel drive on my dana 300
#790981
02/20/07 06:44 AM
need a little help on this one for the last week I was driving in 4 hi ( 2 foot of snow) now the plows finally did there job and cleared the roads my transfer case wont engage the rear axle / drive shaft in 2 hi. In 4 hi only the front pulls i have the stock singlr shifter.
A Jeep, A Harley, A House, I think I have it all
Re: no 2 wheel drive on my dana 300
[Re: hdrulz]
#790982
02/20/07 11:41 PM
Linkage...or do you still have a rear driveshaft under there? Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#790983
02/21/07 02:40 AM
drive shaft is still on un locked hubs (front) and had girlfriend run through 4low to 4hi front drive shaft moved jeep didnt ie. no power to the rear
[Re: hdrulz]
#790984
02/21/07 02:43 AM
Did you hear any nasty grinding or metal breaking sounds while you were driving around in the snow? It sounds to me like either part of your linkage that works the rear shift fork broke or bent, or you did some serious damage to the t-case. Is it leaking?
[Re: Bigbird79]
#790985
02/21/07 02:44 AM
what does it do in 4 low?
[Re: Bigbird79]
#790986
02/21/07 05:06 AM
its an 82 all original CJ7 /w a 151 cid. 4 speed I swapped a black diamond 3" lift and 33 X 13.5 super swampers ( I bought it with 32's and stock springs) everything leaks but no aparent damage to the case no grinding or breaking sounds
[Re: Bigbird79]
#790987
02/21/07 05:10 AM
front shaft spins nothing at the rear im gonna pull the case tomorrow
[Re: hdrulz]
#790988
02/21/07 03:04 PM
I would take a real close look at your linkage before you pull it. There should be 2 shafts moving in and out of the T-case when you move the shift lever. You may have just damaged part of the linkage and are only moving the front shift fork. You may need to pull the case too, but its a lot easier to lay under the jeep and have someone shift it before you pull it.
[Re: Bigbird79]
#790989
02/25/07 06:51 PM
both rods move in and out I eaven checked to make sure they were indixing properly (looking through the inspection cover) only the front drive shaft spins in 4 hi or low
[Re: Bigbird79]
#790990
03/01/07 04:31 PM
I found the problem the set screw in the shift fork came loose if Im thinking correctly in goes into what apears to be a locating hole at the end of the shift rod PS thanks for the advice and help
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6297 MB (Peak: 0.7207 MB) Data Comp: Off Server Time: 2026-10-22 04:05:43 UTCValid HTML 5 and Valid CSS
