Page 3 of 19 1 2 3 4 5 … 18 19
Re: Ranger - Montero Diesel Swap thread [Re: dylanb] #791323 03/09/07 11:39 PM
G
guzzilapd Offline
whats a good Dzl to swap into a 1991 3.0 montero LS? When my 3.o gas gives up? Anything I can buy over in Japan or Philippines and have shipped? I get a 75% discount on Fedex if I take it to the airport and travel frequently to Philippines.
Re: Ranger - Montero Diesel Swap thread [Re: guzzilapd] #791324 03/10/07 08:41 PM
pmontero Offline OP
I just got back from NAPA and Advance Auto Parts and purchased the following parts list for the swap:
'87 Mitsubishi Montero SWB 5 speed manual 2.6 Parts:
Felpro oil pan gasket - NAPA (part number coming)
motor mounts x 2 - NAPA BA1041231
'86 Ford Ranger 5 speed 2wd 2.3 Turbo Diesel Parts:
rear main seal and gaskets - NAPA FPGB540444
vacuum pump - NAPA NVP641012
clutch kit - NAPA NNCMU478011C
Felpro valve cover gasket - Advance VS50100R
Felpro valve cover grommets - Advance ES70342
The parts should be here by next weekend. I will update this post with verified part numbers from boxes when I have them in hand.
Pmontero
'87 Montero Diesel
'98 Porsche Boxster Electric
and more...
Greasology
NotPetroleum
Re: Ranger - Montero Diesel Swap thread [Re: pmontero] #791325 03/14/07 10:01 PM
pmontero Offline OP
I picked up all of the parts today and bought the '87 Montero for the swap. It's a 2.6 5 speed with sunroof, headlight washers and LSD rear. I have the title in hand.
The next post to this thread should have pics of the first phase of the engine swap.
Stay tuned!
Pmontero
'87 Montero Diesel
and more...
Greasology
NotPetroleum
Re: Ranger - Montero Diesel Swap thread [Re: pmontero] #791326 05/28/07 04:46 AM
pmontero Offline OP
The diesel swap started phase I on Memorial Day weekend. We prepped the 2.6 gas engine for removal Friday afternoon and pulled it on Saturday.
The "Before" Pic:
All connections to chassis removed:
The patient and the donor side by side:
The decapitated patient:
The patient's head and intake:
The physician with his assistant - engine out:
My buddy and diesel mechanic with the "Big Fish":
Tomorrow, I'm prepping the Ranger engine and will get it ready to be pulled soon. The bottom is sealed in polymerized vegoil so it's going to be really fun crawling under and unbolting the bellhousing!
Stay Tuned!
Pmontero
P.S. - A special thank you to Fasteddy for taking my two calls Saturday when we got stuck and were looking for a seasoned vets words of wisdom!
'87 Montero Diesel
and more...
Greasology
NotPetroleum
Re: Ranger - Montero Diesel Swap thread [Re: pmontero] #791327 05/29/07 08:21 AM
LandRaider Offline
I sure wish I could come help you on this swap. Watching with loads of interest. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Ranger - Montero Diesel Swap thread [Re: LandRaider] #791328 05/29/07 11:55 AM
lordtrunks Offline
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Ranger - Montero Diesel Swap thread [Re: lordtrunks] #791329 05/29/07 04:26 PM
dylanb Offline
sweet... mine should be ready to get started soon
85 4x4 Pickup, 267K, 4d55 Conversion, Sway-A-Ways, Dual Batteries
Re: Ranger - Montero Diesel Swap thread [Re: pmontero] #791330 06/15/07 07:11 AM
stevegreasecar Offline
I have a power ram 50 with the 4d55t motor that I want to put into my 84 bronco 2( gas 2.8 v-6 broke the timing chain yesterday)... if I buy the ranger motor mounts for d55t at the parts store... will it allow me to bolt the motor in? or do I have to change mounts on the frame? if so...does anyone have some of these mounts that they would be willing to sell/part with? can I remove the bellhousing from the d50 trans and bolt it to the ranger/bronco 5 speed trans? I think they are the same trans... anyone have any other suggestions for the swap?
thanks for your input! I'm a new member to this board.
when it's done I'll post the results with digital pics.
73 Chevy short wheel base van/1 ton 4x4 conversion... soon to have a Cummmins 12 valve
85 VW rabbit "caddy" diesel pickup
84 Bronco II... soon to be implanted with a Mitsu 4d55t heart!
all going to run on SVO or biodiesel!
Re: Ranger - Montero Diesel Swap thread [Re: stevegreasecar] #791331 06/29/07 07:19 PM
dylanb Offline
So I got staretd ripping and stripping for my diesel swap earlier this week. Decided to start on the ranger first.
Remains of the Ranger....
A couple of shots of the engine after pressure washing
My truck, the eventual destination for the diesel...
Sorry for the image sizes, forgot to resize before uploading 'em.....
I've kind of started to worry about wiring the various systems I will need (glow plugs, fuel pump relay, a/c) as wiring is far from being a strong point for me. Can anyone who has done this before share their solution(s)?
Hoping to start pulling the 2.6 out of the truck this weekend, I'll continue to post on my progress.
Re: Ranger - Montero Diesel Swap thread [Re: dylanb] #791332 07/16/07 09:53 AM
LandRaider Offline
Updates?
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.009s) Memory: 0.6551 MB (Peak: 0.7792 MB) Data Comp: Off Server Time: 2026-11-03 19:37:10 UTC
