Page 7 of 19 1 2 … 5 6 7 8 9 … 18 19
Re: Ranger - Montero Diesel Swap thread [Re: 89Diesel] #791363 11/07/07 10:52 PM
lordtrunks Offline
or you could just go buy the right mounts <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Ranger - Montero Diesel Swap thread [Re: lordtrunks] #791364 11/07/07 11:12 PM
8
89Diesel Offline
I wish it was that simple. <img src="/forums/images/graemlins/smile.gif" alt="" /> Where I'm located at, I can't even get an oil or fuel filter! No kidding, we have a pop of 250,000 and the auto parts stores have no idea what a Mitsu diesel engine is! <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> I've only seen one other Mitsu diesel in the country. <img src="/forums/images/graemlins/confused.gif" alt="" />
A day late, A dollar short, and A half a mile behind...
pass me that crescent hammer...
Re: Ranger - Montero Diesel Swap thread [Re: 89Diesel] #791365 11/10/07 03:35 AM
PA_JERO Offline
well I dont have the mounts off the diesel block <img src="/forums/images/graemlins/confused.gif" alt="" /> but I compaired the 2.6 ones to the 2.3 block and they are the exact same.
Re: Ranger - Montero Diesel Swap thread [Re: PA_JERO] #791366 11/10/07 08:04 PM
dylanb Offline
Alright then.... don't know what I was thinking the last few times I looked at the block, but yeah.... I got the motor mounts on a few minutes ago. Going to the store for some bolts and probably going to get the diesel dropped in today.
85 4x4 Pickup, 267K, 4d55 Conversion, Sway-A-Ways, Dual Batteries
Re: Ranger - Montero Diesel Swap thread [Re: pmontero] #791367 11/10/07 11:36 PM
rockrenegade Offline
I didnt realize a 2.6 4x4 pan would work on the deisel. I wound up building a whole new rear sump oil pan. I just cut the pick up in half and mounted it in the bottom of the pan and ran a hose between the oil pickup and the flange.
84' twin turbo diesel PowerRam 50, Rockwells, 4 linked, 47" LTB's, dual cases
Re: Ranger - Montero Diesel Swap thread [Re: 89Diesel] #791368 11/14/07 10:56 AM
Have you tried locating parts through a Mitsubishi Dealership? Not many people know about mitsu diesels around this area either. I found basic stuff ( filters exc ) at a local auto zone, had to order them though. I was able to find everything else I asked for ( pistons, injectors, turbo rebuild kits ) at the dealer. They even had it all in stock. So I would try that if you havent already.
Re: Ranger - Montero Diesel Swap thread [Re: pmontero] #791369 12/02/07 02:21 PM
kcyule Offline
who are the "BREAKERS" in missouri that have these ranger diesels?I NEED a crankshaft pulley in a bad way!:)
thank you
kc
Re: Ranger - Montero Diesel Swap thread [Re: kcyule] #791370 12/02/07 11:27 PM
dylanb Offline
try going to Car-Part.com and seeing what you can find through them.... I'm pretty sure that's how Powell found his parts way out in Mizzou
Re: Ranger - Montero Diesel Swap thread [Re: dylanb] #791371 12/12/07 11:18 PM
dylanb Offline
Okay, so it has been a while, but I just finished finals for the semester and I'm back to working on the truck for a couple of weeks.
Update on the PS pump: It turns out that the shaft diameter on the Ranger's PS pump is smaller than that on the Mitsubishi pump. So, I had the hole in the Ranger's v-pulley bored out to where it will fit (interference fit) onto the Mitsubishi pump shaft. Hacked up the two brackets to come up with one that will work (Mitsubishi pump is a bit larger than Ranger). Here are the results so far, with just a bit of tweaking left to do as it is just slightly skewed still.
Other than that, have to wire up glow plugs, put engine in and see how the clutch feels, and change transmission mounts because mine are ridiculously worn out.
Re: Ranger - Montero Diesel Swap thread [Re: dylanb] #791372 12/18/07 08:05 PM
dylanb Offline
She's in! Got it bolted in before work yesterday. First two things I noticed: the engine bay is now pretty crowded, and the Ford accessories are a good bit above the hood line.
Still got a good bit of plumbing and electrical work to do.... wire fuel pump, charging system, glow plugs, relocate PS reservoir as it is super close to the turbo now, and get creative with the hood. Hopefully get her started in the next week or so.
PHP: 7.4.33 Page Time: 0.024s Queries: 16 (0.019s) Memory: 0.6513 MB (Peak: 0.7766 MB) Data Comp: Off Server Time: 2026-11-02 19:26:01 UTC
