Center Support Bearing #791484 02/21/07 03:28 AM
Wing_Nut_OOA Offline OP
i'm working on a 2wd toyota pickup and the carrier bearing bracket has been mutilated.
i'm wondering how it bolts in...
like this:
or like this:
Re: Center Support Bearing [Re: Wing_Nut_OOA] #791485 02/21/07 04:14 AM
so apparently this is greek?
Re: Center Support Bearing [Re: Wing_Nut_OOA] #791486 02/21/07 04:20 AM
I just replace the center bearing on my '85 4wd two weeks ago. Mine mounted up like your first drawing. You could also look at the way the frame is in the mounting location and match it up. My guess is that it will be like your first drawing. But check the mounting location and go from there, it should be able to only mount one way.
Chris
Re: Center Support Bearing #791487 02/21/07 04:25 AM
the mount for the bearing that is welded to the crossmember has been mutilated by the drivline breaking and slamming around.
so i really wasnt sure which way the tabs went.
Re: Center Support Bearing [Re: Wing_Nut_OOA] #791488 02/21/07 05:23 AM
i guess i'll just guess and fab a bracket out of 1/4 inch steel..
piece of cake!
Re: Center Support Bearing [Re: Wing_Nut_OOA] #791489 02/23/07 12:47 AM
well here it is!!!
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6080 MB (Peak: 0.6777 MB) Data Comp: Off Server Time: 2026-10-21 17:31:10 UTC
