Re: is this normal [Re: smokn03] #791506 02/22/07 04:42 AM
trythis Offline
it may be that the timing chain cover has a hole worn in it and that would explain oil in coolant. You should take off your oil pan and clean out the remnants of the chain guide.
Re: is this normal [Re: trythis] #791507 02/26/07 01:51 AM
smokn03 Offline OP
ok i replaced the timing chain today.it looks like is has been done before.you can see marks in the cover.but i think they just replaced the guides and not the chain.can it make a truck run better with a new chain or am i imagining things?seems to run a little better now.and its olot quieter now to.can you mesure the old chain to see if it was strechted?
Re: is this normal [Re: smokn03] #791508 02/26/07 04:15 AM
cktoy Offline
mine seem to run better after I put in a new timing kit.TYhat and adjusting the valves made mine much more quiet.
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: is this normal [Re: smokn03] #791509 02/27/07 03:53 PM
TimsToyo Offline
If there was slack in the chain then yes. Mine was the same way after I replaced my TC. It ran a lot smoother.
'86 Toyo 4wd
'04 600RR
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6057 MB (Peak: 0.6773 MB) Data Comp: Off Server Time: 2026-11-03 17:12:46 UTC
