90 toyota elctrical problems need feedback #791706 02/22/07 03:24 AM
bluyota Offline OP
SO I was driven down the road and my truck spits and sputters and shuts off I coast over to the side and pop the hood my ign. wire shook loose so reconnected it and it will turn over but wont start. So I checked the fuses and the EFI fuse was blown I replaced it and immediatley after I started it, it blew the fuse.. So whats goin on is a bad ground or what do I need to do!! ??? I need somefeed bak pls...
Re: 90 toyota elctrical problems need feedback [Re: bluyota] #791707 02/22/07 03:41 AM
4Crawler Offline
Common cause of EFI fuse blowing is the O2 sensor wiring falling against the hot exhaust and melting the insulation and shorting out the signal wires.
Re: 90 toyota elctrical problems need feedback [Re: 4Crawler] #791708 02/22/07 03:55 AM
bluyota Offline OP
ok thanks that narrows my problem down and I dont know a whole lot on electrical things but where would this O2 sensor be located would that wire run to the top of my airbox where the air flow meter is!!??
Re: 90 toyota elctrical problems need feedback [Re: bluyota] #791709 02/22/07 04:00 AM
4Crawler Offline
The O2 sensor senses O2 (i.e. oxygen) in the exhaust gas inside the exhaust manifold. So that is a good place to look for it and also one reason why the wires running to it can fall against the hot exhaust. Depending on your smog equipment setup, you may have 1 sensor before the catalytic convertor or a 2nd sensor after the cat as well.
Re: 90 toyota elctrical problems need feedback [Re: 4Crawler] #791710 02/22/07 04:07 AM
bluyota Offline OP
ok cool thanks so what would be a good way to replace the wires that might have been melted on the exhaust manifold <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 90 toyota elctrical problems need feedback [Re: bluyota] #791711 02/22/07 04:14 AM
4Crawler Offline
Step 1. Find out if that is the problem.
Step 2. If it is indeed bad, then look at where the damage is and sdecide on a course of repair. It is likely a multi-conductor, shielded cable and the best bet would be to get a replacement section at a junkyard or perhaps from the dealer or maybe an electronics shop. Any splicing is best done by soldering the individual wires together then heat shrink tubing for insulation around each wire then heat shrink around the whole cable for added protection. It also may be that the wiring can be repaired, maybe just separate the melted wires and re-insulate each one.
Re: 90 toyota elctrical problems need feedback [Re: 4Crawler] #791712 02/23/07 07:22 PM
bluyota Offline OP
hey I checked the wires to the O2 sensor and the wires runnin by the exhaust and they all looked fine. So I called a yota mech. I know and he said it would be the EFI relay in the fuse box so I ordered one last nite so would that sound like my problem.. a blown EFI relay!!!?? <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6225 MB (Peak: 0.7130 MB) Data Comp: Off Server Time: 2026-06-09 21:35:25 UTC
