Gen1 Maintenace Required light
#791883
02/22/07 11:36 PM
So I was out at lunch today with my wife, and both of us were watching the odometer in the Raider tick over 200,000, and almost immediately the "Maint. req'd" light flashed on and I thought to myself "well, DUH!" <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> I'm almost tempted to leave it on as a reminder -- I really like my Raider, but it's definitely NOT a low-maintenance vehicle <img src="/forums/images/graemlins/smile.gif" alt="" />
Just something I found amusing today and thought I'd share <img src="/forums/images/graemlins/kewl.gif" alt="" />
Eric W.
Re: Gen1 Maintenace Required light
[Re: 89IsMine]
#791884
02/22/07 11:44 PM
Same thing a month ago, except 150,000. Another 50 to go...
98 Gen 2.5 05 Pontiac GTO 91 Corvette ZR-1 2011 Kia Sorento (wifey mobile) Clarkdale, AZ
[Re: 89IsMine]
#791885
02/23/07 08:24 AM
Does this even exist in our Gen 1? I have never come across it before except for the alternator, brake, hi beam, and one other I can't recall now. Definitely not any maintenance required light.
[Re: Lester]
#791886
02/23/07 04:07 PM
Yep. In the v-6s there was a "Maint. Reqd." light.
87 Montero, bought new, by me - 88/89 intercooled Starion Turbo engine- with awesome audio.
[Re: 89IsMine]
#791887
02/23/07 05:23 PM
Eric,
You know how to shut if off after you do the maintenance right? Let me know if you don't.
Ray
[Re: off-roader]
#791888
02/23/07 06:53 PM
Eric,
Ray I do Ray -- thanks for checking! I just found it amusing, and figured someone else might get a kick out of it as well. I also found the line about the warning light in the FSM amusing... Note that the warning lights bulb should be removed after the 120,000 mileage I guess someone must have forgotten to do this <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> Eric W.
[Re: 89IsMine]
#791889
02/23/07 08:05 PM
There is also a switch on the same panel to reset the light if you dont want to remove it. I just removed mine and didn't think about it again.
[Re: dadrab]
#791890
02/24/07 01:06 AM
Opps, I missed the sig on the 6 banger. I was thinking of the 4. Cheers.
[Re: 89IsMine]
#791891
12/08/07 12:32 AM
What is the procedure to cancel the light
89 Dodge Raider V6 Auto Black n Gold
[Re: 1009]
#791892
12/08/07 12:37 AM
Pull off the plastic thing behind the speedometer. Find a small black switch and switch it. I forgot what side it was on. It should take you less than 2 min. No tools required, well maybe to switch the switch, it is recessed somewhat.
