The Search is Over! #791904 02/23/07 12:39 AM
Wing_Nut_OOA Offline OP
i dont know if many of you have tried to put a camshaft in your 4.2/4.0
but if you have you've probably noticed that you have to have the head machined for the provided valve springs to work.
and in some cases...the springs they send absolutely WONT work. (coil bind before max lift is achieved)
so i've been searching for months on end for a set of valve springs that would give me everything i needed without any machine work
the answer was in Australia!
Performance Springs (.com.au)
The part number is 5003.
--107.5 seat pressure at 1.625 installed height
--1.340 O.D./.990 I.D.
--Coil Bind= .970
This spring is perfect for I.D. and it bumps up the seat pressure from 70ish to 107 for performance cams
and the low coil bind allows for lift of upto .655 at the valve!!!!
since 4.0's have a 1.7 rocker arm ratio this provides quite a problem because most cams are sent with specs for 1.5 and 1.6 ratios.
the cam i have will give me .544 lift at the valve and i can install these springs and i wont have to mill the spring seats or buy different retainers.
and the best part?
these springs, shipping included, are cheaper than any comp or crane springs that i have found.
Actually finding someone that would send them to me was quite a chore but after emailing about 10 Different vendors someone directed me to
allenw@performancesprings.com.au
he accepts pay pal and is a great guy to deal with.
MOD AWAY!!!
Re: The Search is Over! [Re: Wing_Nut_OOA] #791905 02/23/07 01:20 AM
BigJim Offline
Thanks wingnut for a great post!!!
Re: The Search is Over! [Re: BigJim] #791906 02/23/07 05:07 PM
happy to oblige!
these springs should allow for ANY camshaft that is sold for the 4.2/4.0 (exception of custom ground cams)
its almost too good to be true!
Re: The Search is Over! [Re: Wing_Nut_OOA] #791907 02/23/07 09:16 PM
BigJim Offline
I sure hope them aussies know how to measure!
Re: The Search is Over! [Re: BigJim] #791908 03/06/07 10:45 PM
UPDATE!
the shipping company that allen uses is Astralia Post.
so when it gets here it will be sent US Mail instead of UPS or DHL or FED Ex.
so if you have a PO box for mail, it will greatly speed things up, as the post office doesnt like to go the extra mile to figure out what address matches the PO box...
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6053 MB (Peak: 0.6709 MB) Data Comp: Off Server Time: 2026-10-21 17:31:06 UTC
