Crush sleeve eliminator
#791937
02/23/07 03:34 AM
I'm gonna be regearing pretty soon here, gonna go to 4.88's with 35's <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
I was reading something about using a crush sleeve eliminator, is this worth it?
1984 Toyota Pickup 22R, carbureted Aussie lockers front n rear 4.88 gears 35's Full exo Marlin crawler
Re: Crush sleeve eliminator
[Re: zachtheterrible]
#791938
02/23/07 04:02 AM
In my opinion yes ..
when I did my ARB's .. I used the OE spacer out of the 79-80 toys , and the shims .. 1 time set up .
#791939
02/23/07 05:27 AM
I was reading something about using a crush sleeve eliminator, is this worth it? Yep!!!!!!
"Serenity through Sobriety"
Re: Crush sleeve eliminator <<get it.>>
#791940
02/23/07 05:57 AM
All the Toyota diffs I built have a solid spacer. no crush sleeves. Just do it. Peace.
[Re: leiniesred]
#791941
02/23/07 07:44 AM
were can i get these at? i had one and used it now i am setting up another pair of 4.88 and am about to set up a pair of 5.29. i just bought a regular crush sleeve from the dealer for $14. there is no way i could get a crush sleeve eliminator from them cause whenever i get parts from them they will not look anything up without a vin#. they suck (both local dealers) i couldnt get them to look up the starter rebuild kit... they said it didn't exist. i got the part # and finaly they ordered it for me. its like pulling teeth with them.
stuck in the mud somwere in the swamps of jersey
[Re: pineymudder]
#791942
02/23/07 07:48 AM
never mind i found the # in the part # thread... who would have thought to look there? # 41231-39010
[Re: pineymudder]
#791943
02/23/07 01:57 PM
Okay The spacer is used with shims correct? Use appropriate shims to get correct pinion bearing preaload? Seems better to have this if you have to repair the diffs and beat trying to crush the sleeve. Any input would be appreciated.
1989 TOYOTA PICKUP 4"trailmaster, 3" Body Lift 8,000 lb warn winch, q-78 tsl super swampers
[Re: maxxis85]
#791944
02/23/07 03:29 PM
Toyota Section Staffer
You nailed it. Pinion seal replacement becomes painless as well. I don't know about strength claims, but they make sense. Sooooo much easier to set up gears. P.S. get a good inchpound torque wrench, if you don't already have one. And http://www.gearinstalls.com (our own ZUK) is very helpful.
-Bill '87 4Runner w/ '96 5VZ-FE, 'Red Chili II' '97 Taco XtraCab 3RZ-FE, 'BlackBean' TLCA # 13257, Rising Sun 4x4 Club Land Use Coordinator "He who stops being better stops being good." -Oliver Cromwell
[Re: leiniesred]
#791945
02/23/07 03:30 PM
All the Toyota diffs I built have a solid spacer. no crush sleeves. Just do it. Peace. Is this Rudeboy from Rising Sun?
