T100 Headlight upgrades? #792039 02/23/07 02:27 PM
jmoser Offline OP
What is the story on 'de-yellowing' the headlight lenses?
I would like to install superwhite bulbs but not if they will get lost in crummy lenses. Compared to my other vehicles the T100's lamps look like whale oil lanterns.
Jeff
96 T100 SR5 4WD Ext Cab, Warn Hubs, HD torsion bars, Bilsteins, Camper Shell, TJM bar, factory 31 x 10.5's, Powertrax No-slip rear, Recaro driver's bucket
Re: T100 Headlight upgrades? [Re: jmoser] #792040 02/23/07 03:28 PM
H2O_MAN Offline
I was able to clean my lenses with a few applications of liquid Nu Finish.
I installed PIAA bulbs and all was good - then I sold the T100 in favor of a Tundra.
HTH ~
Re: T100 Headlight upgrades? [Re: jmoser] #792041 02/23/07 04:24 PM
CJMT100 Offline
Ive used light duty rubbing compound before, works like a charm.
Re: T100 Headlight upgrades? [Re: CJMT100] #792042 02/23/07 04:51 PM
adam Offline
I installed a Painless harness and some GE Nighthawk bulbs that have helped a lot without treating the lenses, although I have one of the Permatex restoration kits to use once I get the spare hour and inclination.
A couple others have made up harnesses with Daniel Stern parts and reported results like I got from the Painless wiring.
Unfortunately, the lenses won't support super high wattage bulbs (I got some PIAA 100/135s with the harness), and there aren't, as far as I could come up with, glass lenses available for the T.
edit -
Hang on, H2Oman...what wattage were the PIAAs you used? All was good?
~Adam
Re: T100 Headlight upgrades? [Re: adam] #792043 02/23/07 08:34 PM
ErikB Offline
Toyota Moderator
I used the Permatex headlight lens restoration kit and upgraded the bulbs to the +30 type from Daniel Stern and it made a noticable improvement. The +50 type work well too, but seem to have a shorter life span.
http://www.permatex.com/products...Kit.1.htm
http://www.danielsternlighting.com/
http://home.4x4wire.com/erik
Re: T100 Headlight upgrades? [Re: ErikB] #792044 02/24/07 02:05 AM
dogslovetrucks Offline
I replaced my lenses, and did daniel stern bulbs. WOW what a difference. Wished I tried permatex fix first. I am going to put a set of hella ff into the bumper when it warms up. Then it should be really rocking.
Re: T100 Headlight upgrades? [Re: dogslovetrucks] #792045 02/24/07 05:48 AM
BamZipPow Offline
I used the Mother's Powerball with an electric drill (keeps the fingers from gitting all beat up and blistered using sandpaper) and some Meguiar's Plastic Polish. Just start out slowly and eventually speed up the drill. Before you know it...it looks and performs like new fer a fraction of the cost... <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: T100 Headlight upgrades? [Re: BamZipPow] #792046 02/24/07 10:20 AM
CJMT100 Offline
I dont know if they are really worth it, but I got a set of sylvania xtravision halogens that sync up pretty close with the daniel stern +30's and I like them alot.
Re: T100 Headlight upgrades? [Re: CJMT100] #792047 02/24/07 07:01 PM
Sneaky_Snapper Offline
Do those sylvania bulbs plug directly into the existing fixture with no modifications. Also, is the color white. I am not looking for the European blue tint.
Thanks, I plan on working on my lenses this weekend.
Brad
1997 T100 SR5, X-Cab, V-6, Auto, 113,000 miles, Bilstein shocks
Re: T100 Headlight upgrades? [Re: Sneaky_Snapper] #792048 02/24/07 07:03 PM
CJMT100 Offline
Yep, they plug right in and are white. I bought them at walmart for like 20 bucks.
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.009s) Memory: 0.6382 MB (Peak: 0.7582 MB) Data Comp: Off Server Time: 2026-10-21 19:04:03 UTC
