diff. drop verification #792056 02/23/07 03:30 PM
P
pete3 Offline OP
just trying to verify that if i drop the front diff. 1.25"-1.5", nothing else will need to be modified (other than the cross member). steering components and everything else should remain the same and clear. is my thinking correct?
thanks.
pete
1989 trooper-3" susp. lift, h.d. indy4x tie rods, aisins, tera lows, aussie locker(front)/lincoln locker(rear), 33" mud grapplers on black rock crawlers, homemade bumpers and sliders, hella 500's, surco roof rack, paint & body by busch light
Re: diff. drop verification [Re: pete3] #792057 02/23/07 04:04 PM
onebadtrooper Offline
Yeah Pete. The crossmember will have to be cut to clear the diff. Also the oilpan skid plate has to be bent some, But at barnwell I didn't see one on your truck.
Are you installing a front locker at the same time??
Its a pain to get that front axle out.
Re: diff. drop verification [Re: onebadtrooper] #792058 02/24/07 01:02 AM
P
pete3 Offline OP
hmmmmm.... <img src="/forums/images/graemlins/ignore.gif" alt="" />
yeah, i don't guess i have an oilpan skid plate. just wanted to make sure nothing interfered with my steering.
pete
Re: diff. drop verification [Re: pete3] #792059 02/24/07 01:27 AM
So you are putting a locker in ha. you lucky <img src="/forums/images/graemlins/mrt.gif" alt="" />
Its probably a good thing I can't make it to mega run. I couldn't keep up with ya <img src="/forums/images/graemlins/ignore.gif" alt="" />
here you can see the skid...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6021 MB (Peak: 0.6577 MB) Data Comp: Off Server Time: 2026-05-29 19:57:34 UTC
