1986 2.2 C223T Mystery Antifreeze Leak #792173 02/24/07 02:38 AM
Rxfire Offline OP
I am embarrassed that I cannot locate the leak. It happens when fully warm, at cruise (60-65 mph). It SEEMS to be at the junction of the thermostat housing and the block, at the base of the valve cover (front and center).
But, when fully warm, with a stick braced on the throttle at 2800 rpm, no evidence. Cruise down the hiway, gets warm, you can smell it, get out and there are very limited "spots" of spray on hoses. Topside only, And residue at the front/center location. I have pressed fittings, squeezed hoses, no luck. Some corrosive looking areas on the thermostat housing under the temp sensor leads area. I even suspected a tiny crack in one of the heater hose metal tubes, but no luck.
Thanks for any suggestions
Any suggestions?
Re: 1986 2.2 C223T Mystery Antifreeze Leak [Re: Rxfire] #792174 02/24/07 06:45 AM
Paul223 Offline
Rxfire--
I had my n/a C223 leak from the thermostat housing and tightening it did no good. So, I removed the t'stat housing from the head and found some corrosion on the gasket faces. But, worse, I found that the t'stat housing gasket face was badly warped; ie, not flat. It is a fairly thin section and there are only four bolts to hold it down, looks like a recipe for warpage.
What I did was to use a large piece of very sharp abrasive paper on a flat plate to cut the surface down to flat, and this cured the leak. This had to be seven plus years ago.
I like Permatex #2 for gaskets like this.
Paul
Re: 1986 2.2 C223T Mystery Antifreeze Leak [Re: Paul223] #792175 02/24/07 12:32 PM
Rxfire Offline OP
Thanks Paul. I have another junk engine, I can pull both, select the best, shave that one if needed, and I might as well put a new thermostat in while I am there. That seems to be the area, and would open up when hot. Permatex #2!
Re: 1986 2.2 C223T Mystery Antifreeze Leak [Re: Rxfire] #792176 02/25/07 07:38 AM
Paul223 Offline
Rxfire--
OK, good deal. Keep us posted on how this works.
Paul
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.5998 MB (Peak: 0.6557 MB) Data Comp: Off Server Time: 2026-07-15 02:24:26 UTC
