85-95 22R/RE Flywheels? #792201 02/24/07 02:51 PM
Buster Offline OP
2WD vs 4WD flywheels, is there a difference or are they the same and interchangeable?
Re: 85-95 22R/RE Flywheels? [Re: Buster] #792202 02/24/07 08:29 PM
Vanishing_Point Offline
They are interchangeable but I believe the 4wd might be heavier.
America's first fourwheel drive was built in Mankato, MN by Ernest Rosenburger in 1908 who founded Four-Traction Auto Co. on Hickory Street. The company though successful closed in 1913.
Re: 85-95 22R/RE Flywheels? [Re: Vanishing_Point] #792203 02/25/07 02:24 AM
CJM Offline
same thing ... and completely interchangeable
83 Trekker SR5
NEW Trekker forum
Re: 85-95 22R/RE Flywheels? [Re: Buster] #792204 02/25/07 06:11 AM
jasonmt Offline
79-91 20/22R/RE flywheels are the same and in 92 the 22RE switched to the 22RTE sized 9 5/16" flywheel increasing in size from 8 7/8".
Re: 85-95 22R/RE Flywheels? [Re: jasonmt] #792205 02/25/07 12:00 PM
kyle-22r Offline
if you compare parts numbers from napa you get the same result...but they are different at the dealer.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: 85-95 22R/RE Flywheels? [Re: jasonmt] #792206 02/26/07 01:42 AM
matts Offline
I'm running a '95 flywheel on the back of my '86 motor. Paid $35 for it at a local boneyard. I got it so I could get the bigger clutch while I was upgrading to the R151F tranny. I've pulled a trailer a lot the last year or so, and it's working fine. All my 22R and RE 4WD flywheels seem to weigh 25lbs. -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
Re: 85-95 22R/RE Flywheels? [Re: matts] #792207 02/26/07 07:00 AM
ToYPU Offline
I have a stock 87 yota with 22re can i upgrade to the larger flywheel and clutch? It needs a clutch and flywheel bad.
Thanks
Kevin
22RE OWNERS CHECK FOR DEBRIS IN YOUR OIL PANS! YOU MIGHT SAVE YOUR MOTOR!
*** 1989 Toyota pickup 22re 5spd 4wd ***
* New mods *
  • 305/70/R16 (33X12.5)
  • 2 in suspention lift (zuk coils)
  • minor body work
Re: 85-95 22R/RE Flywheels? [Re: ToYPU] #792208 02/27/07 06:22 AM
matts Offline
Thanks
Kevin
The 9-5/16" flywheel found on the '86 -'88 22RTE (turbo) engines and the '93 - '95 22RE's is a straight swap onto any 22R -RE. It's only slightly bigger than the flywheel you've already got, which is 8-7/8", but if you need a new clutch it's worth doing. -- Matt
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6205 MB (Peak: 0.7024 MB) Data Comp: Off Server Time: 2026-07-13 11:03:29 UTC
