Page 1 of 3 1 2 3
Help on engine codes 25 and 26 #792274 02/24/07 11:51 PM
N
Noel Offline OP
My son from So. Cal visited and his
1993 4 runner, auto, 6 cyls has a check engine light
and the codes are 25 and 26 and it idles really rough.
I've been searching and can't find these codes here.
I will continue searching but if you can assist me in figuring out what's wrong, it'll be greatly appreciated. Thanks.
1990 4Runner
1993 4Runner
1995 4Runner Limited
1999 Mustang Cobra
2001 Sport Trac
Re: Help on engine codes 25 and 26 [Re: Noel] #792275 02/25/07 01:34 AM
Adam F Offline
http://www.troublecodes.net/Toyota/
25 Air-Fuel Ratio Lean.
26 Air-Fuel Ratio Rich.
97 4R, stock, daily driver
Re: Help on engine codes 25 and 26 [Re: Adam F] #792276 02/25/07 01:39 AM
N
Noel Offline OP
Thanks, Adam. Would this be caused by a failing O2 sensor ?
1990 4Runner
1993 4Runner
1999 Mustang Cobra
2001 Sport Trac
Re: Help on engine codes 25 and 26 [Re: Adam F] #792277 02/26/07 12:58 AM
jmsdad Offline
My dad's 94 3.0L truck had the same codes. After a leak-down test, we found out a couple valves were burnt.
Full top end rebuild and the truck's good as new. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Help on engine codes 25 and 26 [Re: jmsdad] #792278 02/26/07 05:41 AM
kewlynx Offline
FWIW, it seems the #4 and #6 exhaust valves on these things burn up, due to the restriction of the crossover pipes; headers are a typical retrofit for this.
I don't have a 3.0 myself, but it seems this is what I've been seeing over time with these.
**ubi apis- ibi salus**
Re: Help on engine codes 25 and 26 [Re: kewlynx] #792279 02/26/07 07:49 AM
N
Noel Offline OP
Thanks for the input, guys ...
I'll try this test after I replace the O2 sensor first,
clean the throttle body next, then TPS ...
1990 4Runner
1993 4Runner
1999 Mustang Cobra
2001 Sport Trac
Re: Help on engine codes 25 and 26 [Re: Noel] #792280 02/26/07 09:37 AM
kewlynx Offline
Well, 02 sensors ain't cheap (www.sparkplugs.com)
Clean your t'body and make sure your TPS is set up properly FIRST, then go for the 02 sensor.
I hate seein' folks throw their hard-earned cash after something that could be a simple fix. <img src="/forums/images/graemlins/shame.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Help on engine codes 25 and 26 [Re: kewlynx] #792281 02/26/07 04:50 PM
N
Noel Offline OP
... makes sense smile
... can I use Brakleen instead of carb cleaner
... to clean the throttle body ?
1990 4Runner
1993 4Runner
1999 Mustang Cobra
2001 Sport Trac
Re: Help on engine codes 25 and 26 [Re: Noel] #792282 02/26/07 05:52 PM
N
Noel Offline OP
Kewl,
Thanks for the input. I just finished cleaning the TB and it cleared the problem. I can't believe it's this simple. I guess I need to incorporate this in my maintenance schedule.
Thanks a bunch again to you and all the members here who took their time to respond. You guys rock !
1990 4Runner
1993 4Runner
1999 Mustang Cobra
2001 Sport Trac
Re: Help on engine codes 25 [Re: Noel] #792283 02/27/07 05:37 AM
N
Noel Offline OP
... oops
... spoke too soon. drove the runner for a while
... and CEL came on again
... but this time it is only code 25
... lean Air-Fuel Ratio
1990 4Runner
1993 4Runner
1999 Mustang Cobra
2001 Sport Trac
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6383 MB (Peak: 0.7612 MB) Data Comp: Off Server Time: 2026-06-22 23:03:30 UTC
