1991 2.6 Petrol Strange Noise and Max RPM #792660 02/25/07 10:32 PM
Hi Guys!
My 2.6 petrol Pajero has got a wierd rough Whirring noise coming from the gearbox / Clutch I think... If I put the clutch in, it stops, but if the clutch is out while in neutral, 1,2,3 or 5, it makes the noise... nothing though in 4th.
Any Ideas?
Also, just wondering what the max RPM of this engine is... Mine tops out at 4000, which can be a bit of a problem if you need to overtake. It hasnt really bothered me as in general it is going well and I dont drive it like a racing car. Just wondering if this is normal, and if not, what the reason could be.
Motor has almost 280000km, but still seems strong!
Any help will be appreciated.
Re: 1991 2.6 Petrol Strange Noise and Max RPM #792661 02/25/07 11:49 PM
The engine should climb to well above 4K rpm...you may have some carburetor or ignition issues to check in to.
As for the transmission noise, I think you'll find yourself needing another soon. Noise from these boxes is never good. The reason there is no noise in 4th is because of the direct lock up between engine and output shaft (1:1 gear) and no sychros have to move.
Sorry if this is not what you want to hear. I have to replace the transmission in my Riader, too. <img src="/forums/images/graemlins/frown.gif" alt="" />
Welcome to the Board! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 1991 2.6 Petrol Strange Noise and Max RPM [Re: rxinhed] #792662 02/26/07 04:43 AM
Thanks rxinhed
I appreciate the feedback. Was hoping it was not that bad, but what can you do? <img src="/forums/images/graemlins/scared.gif" alt="" />
I think it is way out of my league to try do this myself so I will take the old girl to the mechanic and have him open her up! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 1991 2.6 Petrol Strange Noise and Max RPM #792663 02/26/07 05:59 AM
powerRam50 Offline
redline is 6000 rpm.and my truck pulls hard all the way up to and past.you might have a bad vacuum secondary on your carb.
Re: 1991 2.6 Petrol Strange Noise and Max RPM [Re: powerRam50] #792664 02/27/07 02:09 AM
JAVYPRO Offline
6000+rpms!!! <img src="/forums/images/graemlins/scared.gif" alt="" /> you are for sure reving the hell out of it <img src="/forums/images/graemlins/lol.gif" alt="" /> Well, I baby mine and I only take it up to 4000rpms other than that only 3000rpms. Now as for my Mazda Rx3 turbo, that baby screams all the way up to 11,000rpms <img src="/forums/images/graemlins/smile.gif" alt="" /> got to love those rotary engines <img src="/forums/images/graemlins/kewl.gif" alt="" />
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: 1991 2.6 Petrol Strange Noise and Max RPM [Re: JAVYPRO] #792665 02/27/07 05:46 AM
powerRam50 Offline
the redline is 6000 but there has been a couple times that i have been pissed and pushed it to 8000 but highly do not recomend that.i am lucky i did not blow my moter.
Re: 1991 2.6 Petrol Strange Noise and Max RPM [Re: JAVYPRO] #792666 02/28/07 11:51 AM
rabsol1 Offline
What I would give to have an Rx-3 to play with...I got bored the other night and spent about 4 hours on YouTube watching Rotary engine videos. One can doubt if they wish, but those engines are incredible!!! Especially ANY video of the Mazda 787B, the warm-up audio of that engine is like a symphonic masterpiece...Wow!
My apologies, we return now to regularly scheduled programming [/hijack] <img src="/forums/images/graemlins/smile.gif" alt="" />
89 TSi Black 5-spd
88 TSi Blue Auto
88 TSi Black 5-spd (parts)
89 TSi Red 5-spd (parts)
92 Mighty Max 2.4 5-spd - Daily Driver
03 Montero Sport AWD Limited, LOADED
90 Montero LS 3.0 Auto
Re: 1991 2.6 Petrol Strange Noise and Max RPM [Re: rabsol1] #792667 03/01/07 05:28 AM
I once saw and heard a Mazda 20B 3 rotor motor. Whole motor minus intake and exhaust bits was smaller than a pony keg. Had well over 500hp in a 1900lb homebuilt, birdcage tube frame, two seater "sports" car. 12000rpms and smooth, I mean really smooth, with the most Gawd awful noise you can imagine, and flame out the straight pipes. However, like all roto's, it only took one overheat and it was toast, or more accurately, the various rotor housing and end/middle plate pieces of the engine sandwich looked kind of like potato chips instead of nice and flat and all sealed up. And there are 3 tips per rotor, and nine tips per engine, and I think I remember that the tip seals each have about 9 parts. That's 81 little finicky thingy dingys, each of which has to be installed just right, and you haven't even touched the edge seals yet, or the lobe seals either.
It's sort of like a good old piston engine Cessna 172, and a solid fuel rocket. The rocket is fast as stink, and makes a glorious smoke column all the way up to clean out of sight, and the sound of the engine is so loud it can kill you, but you can only fly it once. The old slow and ugly Cessna will fly, and fly, and fly, and fly.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6191 MB (Peak: 0.7172 MB) Data Comp: Off Server Time: 2026-06-07 06:01:03 UTC
