Re: 22re fuel injectors [Re: jhksclemm] #792702 03/02/07 08:10 AM
Tundra_Mac Offline
There's probably a dealership in your area that you can talk to. Or you can go on the Internet. I'd pick the latter option, as dealerships tend to be pushy about things like selling you accessories and insurance.
_________________
2005 Toyota Tundra Accesorios - Tundra 4x2 06 Catalog by Toyota Motors
Re: 22re fuel injectors [Re: dcg9381] #792703 03/03/07 07:03 PM
jhksclemm Offline OP
should I be seeing 12v on both sides of the fuel injector connector with the key on? It seems to me that if on side is 12v and the other a pulsating ground that I should only be getting 12v to one side of the plug. I may be wrong.
Thanks for the help
James
Re: 22re fuel injectors [Re: jhksclemm] #792704 03/03/07 11:18 PM
4Crawler Offline
It'll be an intermittent ground connection. Happens at a high frequency, and a digital voltmeter may not catch the fast changing signal. Also, would only show that with the engine running, the duration of the ground pulse would vary with the engine load (more load = more fuel = longer ground pulse duration).
Re: 22re fuel injectors [Re: jhksclemm] #792705 03/05/07 01:23 AM
dcg9381 Offline
James
Yes. The ground doesn't pulse unless you're turning over or running.
If you have a test light that's LED, it should be fast enough to catch the trigger of the injector. Put it across the injector plugs, turn it over, see if you indicate voltage.
22REturbo.net
1988 4Runner
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6078 MB (Peak: 0.6793 MB) Data Comp: Off Server Time: 2026-06-23 01:14:31 UTC
