whats the biggest tires you should put on a truck thats still independent front axle #793099 02/27/07 04:02 AM
d_a_r_kstar Offline OP
Re: whats the biggest tires you should put on a truck thats still independent front axle [Re: d_a_r_kstar] #793100 02/27/07 04:15 AM
4Crawler Offline
Usually fine up to a 33" tall tire. Seems folks start breaking stuff when the go bigger. Plus the cost of lifting the truck to fit taller than 33s can go up quite a bit:
- http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml#FAQ10
Re: whats the biggest tires you should put on a truck thats still independent front axle [Re: 4Crawler] #793101 02/27/07 05:06 AM
P
pineymudder Offline
i have 3" body lift and i fit some 35" gound hawgs. i know they measure up short but i can wheel them in the mud with minimal rubbing. i havent broke anything with them but i only have mud and hill climbs no rocks. and i run 4.88 gears.
stuck in the mud somwere in the swamps of jersey
Re: whats the biggest tires you should put on a truck thats still independent front axle [Re: pineymudder] #793102 02/27/07 06:15 AM
OOP'S Offline
I have seen 40's with a lot of triming and a BL. Broke crap right and left!!!! I just looked at it and said that is stupid!!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: whats the biggest tires you should put on a truck thats still independent front axle [Re: OOP'S] #793103 02/27/07 01:49 PM
grandeyota Offline
I've had many different brands of 35s and some 36" radial swampers on the IFS on mine over the past 9 years. I've still only replaced CV axles due to the boot getting torn. Open diff with 4.88s.
I only see mud here in south FL though, and it's a different kind of stress than people that have rocks to drive on.
Fur clog in the sausage grinder
Re: whats the biggest tires you should put on a truck thats still independent front axle [Re: grandeyota] #793104 02/27/07 02:12 PM
Rodgertheshrubber Offline
i have had good luck with 35s and i may try some 36s (q78) in the future. i have only broken 1 cv and i think that was because it drooped too far and pulled the shaft out too far.
"I am a shrubber, my name is Rodger the Shrubber. I arrange, design, and sell shrubberies"
Re: whats the biggest tires you should put on a truck thats still independent front axle [Re: Rodgertheshrubber] #793105 02/27/07 02:29 PM
maxxis85 Offline
Ive been wheeling my Q-78 TSL's (35.5") and no breakage yet, Prollly wont see any due to me trashing the IFS for SAS
1989 TOYOTA PICKUP 4"trailmaster, 3" Body Lift 8,000 lb warn winch, q-78 tsl super swampers
Re: whats the biggest tires you should put on a truck thats still independent front axle [Re: maxxis85] #793106 02/27/07 02:54 PM
ChrisH Offline
i vote for 33-34's
35 is too big for ifs, IMHO
'95 Toyota Pickup DX Xtended Cab ~ Daily Driver
Re: whats the biggest tires you should put on a truck thats still independent front axle [Re: ChrisH] #793107 02/27/07 11:57 PM
D-runner Offline
Been running 35Æs for over a year with no problems so far but I run mostly trails. I did upgrade the idler arm to a heavy duty one from Total Chaos and I carry a spare CV just in case. Btw: IÆm running 6ö suspension lift with 5.29 gears and locked in the back.
Look at the weight of the tires before you buy. I was looking at MTRÆs and ToyoÆs and the weight difference was around 29 lbs each. I went with the lighter tire, MTRÆs. My old post from last year here .
Adam W.
87 4Runner SR5 - 22RE w RV head & TRD Cam, LCE header, W56B-HD, 4" Stage II, 1.5" BJS, Rancho T-bars, F 5.29, R 5.29 ARB V6 FF w LC disks, 35" MT/R's
85 4Runner frame, 5" Marlin springs, 5:29 ARB HP front. Work in progress - Always!
Re: whats the biggest tires you should put on a truck thats still independent front axle [Re: D-runner] #793108 02/28/07 12:46 AM
eightyeight Offline
35's are ok if you are fairly easy on it, and dont mind fixing stuff occasionally.
i ran 35's on ifs for about a year, grenaded one 4.88 front diff, otherwise ok.
if the truck is going to get thrashed hard, you will break stuff left and right with 35's.
33's are relatively safe.
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6382 MB (Peak: 0.7613 MB) Data Comp: Off Server Time: 2026-05-29 17:53:37 UTC
