oil sender/switch #793123 02/27/07 05:50 AM
michael1990toy Offline OP
Where is the oil sender switch located on 1990 3.0 v6 engine?
Re: oil sender/switch [Re: michael1990toy] #793124 02/27/07 06:13 AM
OOP'S Offline
Right by the oil filter.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: oil sender/switch [Re: OOP'S] #793125 02/27/07 08:47 AM
thanks i thouhgt so but wasn't sure. I think It should have one wire hook up as well. I just bought the truck and trying to fix all the little things that are wrong with it. I found two connectors that not hooked up kind of by the alternator, one is a one wire hookup and the other is a two wire. I think the one wire is for the oil pressure and the two wire might be for the fan heater/ac fan speed, because the fan only works on the highest setting not any of the other settings. Anybody know for sure? Serenity is Awsome, Sobriety is moderationfor me!!
Re: oil sender/switch [Re: michael1990toy] #793126 02/27/07 02:31 PM
fourwd1 Offline
... and the two wire might be for the fan heater/ac fan speed, because the fan only works on the highest setting not any of the other settings. Anybody know for sure?
That's not it.
Your fan isn't working on all speeds because the resistor pack is bad. It's mounted in the ductwork under the dash. You'll see a 3-4 wire connector going into a duct. When you pull out the entire thing it will look like 3 coils of wire inside. They are the fan speed resistors, and are bad.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: oil sender/switch [Re: OOP'S] #793127 02/28/07 12:05 AM
I fixed the oil pressure gauge by re-hooking the wire that was ripped off from the sender. thanks <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: oil sender/switch [Re: michael1990toy] #793128 02/28/07 01:25 AM
Smoke Offline
The other two wire connector is for the ADD, if so equipped, if not then a jumper should be in the connector in order for the 4WD light to work.
94 P/U Ex-Cab 3.0 Automatic 4X4
Re: oil sender/switch [Re: Smoke] #793129 02/28/07 04:34 PM
I have manual hubs, I think it is none ADD. I think it might be for the crankshaft positon sensor. I calling toyota today to get some info. of does anyone have any other advice? thanks
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6133 MB (Peak: 0.6910 MB) Data Comp: Off Server Time: 2026-06-07 09:34:15 UTC
