Parking brake light wont turn off!
#793199
02/27/07 02:59 PM
hey guys, when i take my parking brake off the light will stay on and some times it will come on and off while i am driving. anybody have any sugestions. Thanks for the help, Eric S.
Eric S.
2000 Tacoma -6in of lift,33x12.50 truxx's M/T's
Re: Parking brake light wont turn off!
[Re: EDS2000tacoma]
#793200
02/27/07 05:33 PM
low brake fluid sensor in your master cylinder reservoir, check your front pads for wear, if they're good put a little more in the reservoir, should go away.
[Re: Jake97T]
#793201
02/27/07 05:39 PM
All my stuff checks out and I get the same thing. I hear of a lot of people that get this issue. Mine has got to be the e-brake cable doing something that keeps the sensor on even though it is disengaged. If everything checks out alright and the e-brake is not engaged while driving then it isn't too much of a concern in my opinion.
98' Toyota Tacoma SR5 Manual Xtra Cab, Slight Lift Maine Rules!
[Re: EDS2000tacoma]
#793202
02/27/07 08:42 PM
The sensor in the reservoir cap can also go bad.
[Re: azrain]
#793203
02/28/07 03:12 AM
I have the same problem on my 03 Xtra cab, 4cyl, 5Spd with 49k miles. When I release the parking brake the light doesn't turn off. Sometimes I twist the Parking Brake handle around and push it in at the same time and the light sometimes stays off.
I'll check the brake pads and fluid just in case.
gcinque 03 Tacoma Xtra cab 4cyl 5spd 89 4Runner/Jasper reman 22RE/Auto SOLD 98 Tacoma Xtra cab 4cyl Auto SOLD
[Re: gcinque]
#793204
02/28/07 05:03 AM
i dont know if tacos are the same but on my mini i just disconnected a little switch that the end of the ebrake handle rod thing would push in on the firewall to turn that light off?
87' ext cab toy
[Re: lethe]
#793205
02/28/07 02:58 PM
thanks guys i have got some stuff to try, ill let you guys know what works.
Eric S.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6164 MB (Peak: 0.6899 MB) Data Comp: Off Server Time: 2026-06-06 21:42:30 UTCValid HTML 5 and Valid CSS
