95 4 runner tranny ?? #73067 06/29/03 01:52 AM
O
okidoc Offline OP
I just bought a 95 4-runner w/ the v-6 and 4wd. I've noticed a small tranny leak that appears to be coming from near the top of the drivers side bell housing. I know it is tranny fluid because it is red. Any ideas as to what would cause this? The bellhousing is wet, you can see it from the wheel well, everything else is good to go.
95 SR5 V6/auto, 31 Geo Yokos, nuthin' special, but more reliable than my old Jeep.
Re: 95 4 runner tranny ?? #73068 06/29/03 04:56 AM
code33 Offline
It could also be power steering fluid as it takes ATF.
Classifieds & Suzuki Moderator
Re: 95 4 runner tranny ?? #73069 06/29/03 05:01 AM
spannky Offline
Or red toyota coolant from the head gasket?
Re: 95 4 runner tranny ?? #73070 06/29/03 03:41 PM
O
okidoc Offline OP
Thanks for the help.
I thought about the head gasket but I think I can rule that out right now(runs well, no water in oil, etc), besides if I don't think about it it doesn't exist, right?
But what structures could wet the drivers side bell housing? PS pump is on the pass side, do the hoses go behind the motor, against the firewall? I will check this oput later today.
Thanks again.
Re: 95 4 runner tranny ?? #73071 06/30/03 07:11 AM
Take a good look at the rear heater hoses.. They are also in that corner and I had a leak just like that and it turned out to be one of those small hoses... And as mentioned, being a Toyota, it should have red coolant.. I was puzzled myself seeing as I have a 5-spd.. My first thought was a tranny leak and then it dawned on me that 90 weight is not red <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
Re: 95 4 runner tranny ?? #73072 06/30/03 04:11 PM
O
okidoc Offline OP
O.K. I ran some tranny sealant dexron II as the tranny was low, you know the "formulated for high mileage" stuff and it looks like it may of stopped the leak.
I also did some research on red coolant, mine is green. Should I change it, or leave it. I don't know how long it's been in there but it looks clean. Am I damaging anything? I know the red is intended for diagnostic purposes but other than that what r the differences?
Re: 95 4 runner tranny ?? #73073 07/02/03 03:28 AM
Victor Offline
It is my understanding that Toyota red is better for the water pump. DO NOT put in Dexcool or other orange/red coolant. Those are high silicate coolants and will toast your water pump. If someone puts some green coolant in your Toyota it will turn a reddish brown - which is what mine was until I flushed and refilled it.
94 SR5 4-Runner
167000 Miles and going strong
BJ Spacers, Fj80 coils, MT/R's
Lock Right front and rear
Re: 95 4 runner tranny ?? #73074 07/02/03 02:05 PM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans"> DO NOT put in Dexcool or other orange/red coolant. Those are high silicate coolants and will toast your water pump </font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Just curious why this is the case. I had my radiator off the other day (T belt change) and filled it with DexCool b/c I thought that is what was in there before (looked red, not green, and I didn't know about "Toyota red"). Anyway, looks like I may be chaning the coolant again here very soon, but before I do, just want to understand why the Dex Cool is problematic.
PHP: 7.4.33 Page Time: 0.007s Queries: 14 (0.005s) Memory: 0.6156 MB (Peak: 0.6963 MB) Data Comp: Off Server Time: 2026-06-23 06:08:21 UTC
