Diff gasket #793301 02/27/07 06:51 PM
A
Alloush Offline OP
Would anyone trust a "reuseable" gasket when changing your diff fluid? Or do you stick with RTV. The last thing I want is fluid leaking out my diff.
05 TJ 2.25 BB. Skyjacker hydro 7000 shocks.
Re: Diff gasket [Re: Alloush] #793302 02/27/07 09:21 PM
jstritec Offline
I just use a little pooky myself
Josh
80 CJ-7.
It runs
Re: Diff gasket [Re: Alloush] #793303 02/27/07 10:12 PM
BigJim Offline
I ALWAYS use a gasket!!! I have NEVER used pooky! When using a gasket the cover will come straight off... The factory uses pooky and I have seen warped covers from idiots beating a screwdriver into the edge to get em loose.
Most times...as you indicate... the gasket can be reused.
Re: Diff gasket [Re: BigJim] #793304 02/27/07 11:45 PM
A
Alloush Offline OP
Thanx for the advise Big Jim. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Diff gasket [Re: Alloush] #793305 02/28/07 12:40 AM
Bigbird79 Offline
I agree with Jim for using gaskets anytime I can. However I found with the Chrysler 8.25" rear axle on my 99 XJ that a diff gasket was not available at the local Napa, so I just use some Permatex Ultra Copper, since it was higher temp than Ultra Blue. I haven't had a leak yet, but I sure would rather have a gasket in there too.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6057 MB (Peak: 0.6701 MB) Data Comp: Off Server Time: 2026-06-17 04:18:15 UTC
