XJ Troubles #793549 02/28/07 08:53 PM
MarlboroMan Offline OP
All right, i have a 96 XJ 4.0 auto. I have no idea what the problem is. It keeps throwing the code "cylinder 1 misfire." I don't think it's the timing bc it runs and starts just fine. I put in new plugs, wires, cap, rotor, and coil recently. Any help will be appreciated
Thx
Re: XJ Troubles [Re: MarlboroMan] #793550 02/28/07 11:51 PM
Wing_Nut_OOA Offline
is there anything actually "wrong" with the jeep other than it telling you its misfiring?
Re: XJ Troubles [Re: Wing_Nut_OOA] #793551 03/01/07 12:25 AM
BigJim Offline
Is it idling good or not? I'd pull the #1 plug and look at it. If good I'd swap it for the #2 and see what code I get after that.
Re: XJ Troubles [Re: MarlboroMan] #793552 03/02/07 04:42 AM
yeah, it does misfire, just not very often. and tomorrow i'm going to do a compression check on it, see if it has a cracked head gasket. it idle's low, around 600-700.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.5969 MB (Peak: 0.6522 MB) Data Comp: Off Server Time: 2026-10-26 20:21:45 UTC
