almost stalling when turning #794069 03/03/07 02:43 AM
Hal2000 Offline OP
Today I had to put my sporty in 4WD as we just got almost 12 inches of snow yesterday, and I noticed that when I turn my sporty acts like it wants to stall, more like its jerking. I've never noticed it in 2WD.
Any suggestions where to look?
98 Sportage
Re: almost stalling when turning [Re: Hal2000] #794070 03/03/07 08:50 PM
Cen_Tex_KIA Offline
Might have developed a vacume leak if you're still using vacume hubs. Getting intermitet vacume would cause the motor to hesitate and the hubs to lock and unlock, giving the jerking.
If you have other hubs, check for dirt and corrosion inside, they may need a wd40 soaking to keep locked in place.
Good luck.
2000 KIA Sportage 4x4, Sadly Smushed! Now a 2001 Cheep Jerokee. 3" Rough Country Lift, 255/70/16 General AT2's
http://www.cardomain.com/ride/2292811
Re: almost stalling when turning [Re: Cen_Tex_KIA] #794071 03/03/07 11:27 PM
Hal2000 Offline OP
Yep.. I still have the junk vac ones. I was hoping to change them out before I moved but never got the chance. Looks like thats what I'll be doing now.
98 Sportage
Re: almost stalling when turning [Re: Hal2000] #794072 03/03/07 11:45 PM
Cen_Tex_KIA Offline
Bet thats the culprit, try just blocking the line after the switch (under hood, on firewall, just below drivers wiper)and see if the loss of power goes away (4wd will too). U can replace the lines, but I would get the real hubs. There is something reassuring about turning to "lock", and knowing it's gonna work! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: almost stalling when turning [Re: Hal2000] #794073 03/05/07 02:19 PM
A
Airdale73013 Offline
In 4wd with the hubs locked you will notice drive-line bucking when you turn the wheel, this is normal because you have four wheels traveling different speeds when you are in a turn and the front an rear axles are connected without a center differental. This is normal and one of the reasons you don't use 4wd on dry pavement.
2009 Sorento LX, 4x4, V6, Auto, Red
Re: almost stalling when turning [Re: Airdale73013] #794074 03/06/07 02:14 AM
Hal2000 Offline OP
Oh.. It wasn't dry at all.. A lot of slush and snow..
98 Sportage
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6085 MB (Peak: 0.6781 MB) Data Comp: Off Server Time: 2026-10-24 07:16:52 UTC
