BJ Spacer and Shimmy #794144 03/03/07 07:58 PM
P
PhotoShooter Offline OP
I've got a 97 T100 that I did a 1.5" BJ Spacer lift up front and a slight torsion bar crank and add a leaf in back. Had everything realigned. I've been running this setup for about two months and everything has been working great. The one problem... I get a vibration when I'm in 4 wheel drive going over about 40 mph. Do I need to think about dropping my transfer case to take some of the angle off of the CV joints or is something else going on. Thanks guys
Jon
Re: BJ Spacer and Shimmy [Re: PhotoShooter] #794145 03/03/07 08:23 PM
BamZipPow Offline
How well are yer tire balanced?
Been doing anything weird/different? Did you go roading since then? <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: BJ Spacer and Shimmy [Re: BamZipPow] #794146 03/03/07 09:14 PM
P
New tires and balance and no vibration in 2wd so I don't think its a wheel/tire issue, and not been driving off road recently. Its really only a four wheel drive at speed issue but it definetely didn't have a vibration before the BJ lift so I'm sort of thinking it's the CV angle and at slower speeds I just can't feel it. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: BJ Spacer and Shimmy [Re: PhotoShooter] #794147 03/04/07 02:48 AM
Creeper Offline
I run the ball joint spacers but they were machined down to 1" by Roger Brown. I don't have any unusual vibrations but I don't usually run 40mph or faster in 4wd.
'97 T100 SR5 XCab 4WD
TRD SC ~ ARB ~ FWC
'85 FJ60 Landcruiser
4E9 ~ locked ~ 33's
Re: BJ Spacer and Shimmy [Re: PhotoShooter] #794148 03/04/07 04:42 AM
BamZipPow Offline
Have you measured the angle that the CV joint is at? Take a peek and see if anything is binding...
Re: BJ Spacer and Shimmy [Re: BamZipPow] #794149 03/04/07 08:01 AM
ErikB Offline
Toyota Moderator
Probably CV joint angle is too steep. I had a similar thing happen when I did a spacer lift on my '97 Runner and the angles were too steep. I lowered the lift and it went away.
http://home.4x4wire.com/erik
Re: BJ Spacer and Shimmy [Re: ErikB] #794150 03/04/07 10:11 AM
4
4xGeek Offline
x3... CV angle too high. Let it back down some.
Also, you didn't say if you have manual hubs or not; If not, you should strongly consider. <img src="/forums/images/graemlins/shiner.gif" alt="" />
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: BJ Spacer and Shimmy [Re: 4xGeek] #794151 03/05/07 05:37 PM
P
Was pretty sure my CV angle was the culprit. Thanks for confirming. I'll probably do a front diff drop from 4 crawler in a couple of weeks. Also, the manual hubs are on the long list....... thanks
Re: BJ Spacer and Shimmy [Re: PhotoShooter] #794152 03/06/07 01:17 AM
4
4xGeek Offline
Fwiw, if you plan to wheel I'd move the hubs up the list... Easier to do it 1st than having to replace a CV joint due to too much angle. <img src="/forums/images/graemlins/cheers.gif" alt="" />
4xGeek (Chris)
Re: BJ Spacer and Shimmy [Re: PhotoShooter] #794153 03/06/07 07:01 PM
ErikB Offline
Toyota Moderator
Those are for the later style IFS, not ours...
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6416 MB (Peak: 0.7608 MB) Data Comp: Off Server Time: 2026-06-07 03:50:43 UTC
