Page 5 of 10 1 2 3 4 5 6 7 9 10
Re: Our Trekker/Precision conversion is just a little closer .... [Re: Bogo] #794278 10/21/07 03:02 AM
CJM Offline OP
bolt in strip ... for the headliner I think was the only purpose ..
83 Trekker SR5
NEW Trekker forum
Re: Our Trekker/Precision conversion is just a little closer .... [Re: CJM] #794279 10/21/07 05:13 PM
dknight Offline
nice. I'd like to see a pickup converted into a pop-top camper . . . Maybe one day.
I don't know how your apprentice stayed so clean for those pictures.
Re: Our Trekker/Precision conversion is just a little closer .... [Re: dknight] #794280 10/21/07 05:54 PM
Vanishing_Point Offline
Man, it's amazing what you can do with some fiberglass! By the way there is a trekker for sale in Mankato, Mn.
Re: Our Trekker/Precision conversion is just a little closer .... [Re: Vanishing_Point] #794281 10/21/07 06:01 PM
dknight Offline
Clearly he has practice <img src="/forums/images/graemlins/wink.gif" alt="" />
I think I'd replace those rotted little metal parts with stainless instead of galvinized. Just because.
Re: Our Trekker/Precision conversion is just a little closer .... [Re: dknight] #794282 10/21/07 08:47 PM
Bogo Offline
The problem with stainless is getting the strength and stiffness without getting to thick. Stainless is unfortunately a rather soft metal that fatigues easily.
-- Bryan
-- Bryan
Re: Our Trekker/Precision conversion is just a little closer .... [Re: Bogo] #794283 10/22/07 01:21 AM
CJM Offline OP
got an add ? maybe .
nope .. zinc'd steel 14G incased in fiberglass .. it'll last for 50 Years .
-- Bryan
absitivilly smile
83 Trekker SR5
NEW Trekker forum
Re: Our Trekker/Precision conversion is just a little closer .... [Re: CJM] #794284 10/23/07 12:41 AM
He doesn't have an ad. Only a window sign. I could talk to him though.
Re: Our Trekker/Precision conversion is just a little closer .... [Re: Vanishing_Point] #794285 10/23/07 01:26 AM
CJM Offline OP
if hes on the computer .. send him to
http://toyotatrekker.proboards107.com/index.cgi
Trekker specific board .
83 Trekker SR5
NEW Trekker forum
Re: Our Trekker/Precision conversion is just a little closer .... [Re: CJM] #794286 10/23/07 01:50 AM
dknight Offline
If rusty 22 gauge has held up fine. Then 14 gauge stainless would be strong enough.
The Galvinized is probably much better than originally used. Encased in fiberglass it will last for a LONG time. Until you drill a hole trough it to attach something, then expose that hole to salt, then all bets are off (Unless you are also careful to seal the hole). I'm just saying if I was going to all that trouble I'd spring a couple of extra bucks and use stainless. Yes it is weaker. But you are nearly doubling the thickness, so it would be fine. Not saying what you are doing is wrong, just that I'd do it a little different. Who knows, your way might be better - but I suspect it will take years of abuse of either to find out smile
Again, nice job. Got plans for a lift top camper smile
Re: Our Trekker/Precision conversion is just a little closer .... [Re: dknight] #794287 10/31/07 02:49 AM
CJM Offline OP
so Progress smile
pulled the plastic cover off because it was all cracked and missing pieces where it is riveted onto the door ..
"hemed and hawed" about what I was going to do .. I was going to make a mould , and make a completly new one .. but to much time and money involved there , so I decided to repair the holes , and send it off to line-x as well .. it'll work out great . and match the rest of the rig .
hatch cover repaired
and sanded and ready for line-x
rear hatch is now completly apart , and ready for some line-X
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6515 MB (Peak: 0.7731 MB) Data Comp: Off Server Time: 2026-05-29 15:44:12 UTC
