95.5 Rodeo: Model year differences? #794381 03/04/07 06:08 PM
toowacky Offline OP
I've been doing a lot of work on my wife's Rodeo since we've been together the last couple of years: clutch cylinders, brakes, starter, cleaning TB, and right now in the middle of a water pump turned timing belt, etc. job. Was wondering if someone could clarify the 95.5 model year differences for me. She told me it was a 95.5, and I kinda blew it off until I saw the owner's manual which clearly states 1995.5 right on it.
Mainly, what engine/parts differences might I encounter? Is it safer just to say a 96 when getting parts from non-dealer sources?
Thanks- Tom
1988 4Runner 22R-E W56
1989 4Runner 22R-E A340
1995.5 Rodeo 3.2L 5spd
Re: 95.5 Rodeo: Model year differences? [Re: toowacky] #794382 03/04/07 11:50 PM
RobG Offline
Yes, i routinely refer to my 95.5 as 96 to avoid confusion at the parts counter. Its going to be much closer to a 96 than to a 95.
-Rob
Re: 95.5 Rodeo: Model year differences? [Re: RobG] #794383 03/04/07 11:54 PM
9
94redrodeo Offline
aren't 96's dohc and obd II
I have a 95.5 and the only diffrence I can tell is the newer interior
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
Re: 95.5 Rodeo: Model year differences? [Re: 94redrodeo] #794384 03/05/07 12:08 AM
Canucklehead Offline
OBD II-> Yes, DOHC->No.
Steve
'97 Rodeo 5spd. 3.2L SOHC V6 4WD
Re: 95.5 Rodeo: Model year differences? [Re: Canucklehead] #794385 03/05/07 03:25 AM
9
94redrodeo Offline
Were some first gen rodeos Dohc like the troopers Because I know some were 190hp Vs175hp
Re: 95.5 Rodeo: Model year differences? [Re: 94redrodeo] #794386 03/05/07 04:24 AM
JLEMOND Offline
THE 190 HP CAME IN 96 AS THE OBD11 ENG CONTROL, AND ALLSO THE 95.5 RODEO HAD AIRBAGS 94 DID NOT HAVE THEM , OTHER THAN SOME TRIM AND THE ENG CONTROLS , AND THE AIR BAGS THEY ARE PRETTY MUCH THE SAME AS THE 96 EXCEPT THE ENGS ARE NOT INTERCHANGABLE JERRY,
Re: 95.5 Rodeo: Model year differences? [Re: JLEMOND] #794387 03/05/07 06:27 PM
toowacky Offline OP
Thanks for the info, guys. Jerry, I've got a lot of good info from your posts I've come across searching, appreciate it. Tom
Re: 95.5 Rodeo: Model year differences? [Re: toowacky] #794388 03/05/07 09:28 PM
Rodeo Guy Offline
Ah, the old 95.5 rodeo discussion. The 96s did get the redesigned ifs, with longer control arms and equal length cvs. The rear axle was slightly wider, I think 1.5 or 2"? I believe there was also a difference in the abs system as well. The 96+ got 4wheel abs vs rear wheel, or they moved the location of the sensors, I don't remember.
So unless you are ordering interior pieces, I would tell them its a 95.
Mike
"Damn the carnage! Full throttle ahead!"
95.5 rodeo, 37" Trxus MT, dana 44/9", coil-overs, lockers..... http://www.cardomain.com/memberpage/550454
Re: 95.5 Rodeo: Model year differences? [Re: Rodeo Guy] #794389 03/14/07 09:14 PM
jmcentire Offline
From what I've heard the 95.5 got everything the 96 had except ODBII. I have a 95.5 and would really appreciate a definite answer if anyone is sure since I will be replacing my cvs soon.
95.5 Rodeo 4x4 V6
3" DOR Lift
33x12.5x15 BFG A/Ts
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6266 MB (Peak: 0.7134 MB) Data Comp: Off Server Time: 2026-11-02 04:02:38 UTC
