Any Tips on Fueling Up a New 22RE Pump and Injectors? #794443 03/05/07 12:09 AM
matts Offline OP
My whole fuel system is dry right now. The tank is new, the pump, the fuel lines, the filter and the injector rail are all bone dry. Anything I should do before trying to start it to get the fuel circulating and the air purged? -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
Re: Any Tips on Fueling Up a New 22RE Pump and Injectors? [Re: matts] #794444 03/05/07 12:28 AM
4Crawler Offline
You could put in the fuel pump test jumper and turn on the ignition to run the pump (tank full) and fill the fuel lines, filter, FPR, injectors, etc.:
http://www.4crawler.com/4x4/CheapTricks/index.shtml#FuelPump
Re: Any Tips on Fueling Up a New 22RE Pump and Injectors? [Re: 4Crawler] #794445 03/05/07 04:02 AM
matts Offline OP
I knew such a thing was possible, but didn't remember the details and already passed my daily quota for pages read in the FSM. I really like the idea of pressuring up the fuel system, prior to running the motor for the first time, to check it for leaks or other problems.
While reading 4Crawler's write-up on the process I was glad to stumble across his article on installing a camp shower in your Toyota . Thank you. -- Matt
Re: Any Tips on Fueling Up a New 22RE Pump and Injectors? [Re: 4Crawler] #794446 03/14/07 05:47 AM
TheFabricator Offline
Seem to be having a problem as described on your site. just started this?
But can't seem to locate the connecter as in the pic
I have a 87 re truck
pump doesn't come on until I start cranking the motor
Shouldn't the pump cycle when you just turn the key on for a few seconds
Re: Any Tips on Fueling Up a New 22RE Pump and Injectors? [Re: TheFabricator] #794447 03/14/07 05:54 AM
4Crawler Offline
Test jumper pins may be in the diagnostics box on the later engines (passenger side fender, B+ and FP pins) instead of a separate connector on the driver's side like the '85 has.
And yes, pump normally won't start until you hit the starter, that is normal (unless you ahve the test jumper installed).
Re: Any Tips on Fueling Up a New 22RE Pump and Injectors? [Re: 4Crawler] #794448 03/14/07 10:55 PM
Ok don't have nothing in the diagnostics box
found 1 T connector not plugged into nothing
it is black in color and is by the cold start injector
there is a blue T by the coil, it is plugged into a square
diode ? not sure. but the square thing is going to ground
Re: Any Tips on Fueling Up a New 22RE Pump and Injectors? [Re: TheFabricator] #794449 03/14/07 10:58 PM
4Crawler Offline
Best bet would be to look up the connector location in a Factory Service Manual for your year vehicle:
- http://www.4crawler.com/4x4/FSM.shtml
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6238 MB (Peak: 0.7151 MB) Data Comp: Off Server Time: 2026-06-17 05:23:11 UTC
