wiring for O2 sensor on on 94 p/u ? #794590 03/05/07 04:02 PM
W
wildyota Offline OP
Hi, I bought a 94 toyota 4x4 22re and the wiring for the O2 sensor had been hacked up by the P.O. I bought a "universal" O2 sensor and am having trouble finding/understanding the a wiring diagrams I found. The univerals O2 sensor has 4 wires 1 blue, 1 white and 2 black. Any ideas on how to wire this up to my truck? My truck has 1 black, 1 brown, 1 white/red, 1 black/yellow. I think... that is going from memory..
88 4x4 Toyota - Stock -
Re: wiring for O2 sensor on on 94 p/u ? [Re: wildyota] #794591 03/05/07 04:23 PM
applesauceman55 Offline
Sure, but the wire colors in my 94 electrical manual don't match your descriptions. Here are the connections I have for OX1 (main ox sensor):
Black - goes to ECU OX1 terminal
Pink/green stripe - goes to HT1 (heater) terminal on ECU
Brown - ground
White/red stripe - +B (battery) from EFI main relay
Hope this helps...
1994 Pickup 4X4 22R-E 5 speed
Re: wiring for O2 sensor on on 94 p/u ? [Re: wildyota] #794592 03/05/07 05:38 PM
4Crawler Offline
Re: wiring for O2 sensor on on 94 p/u ? [Re: applesauceman55] #794593 03/07/07 02:45 PM
9
95mini Offline
I have a similar 02 problem with a 4 wire, same colors. The responses to this post really haven't helped me out. I don't really need to know which wire is which, i need to know which one to connect. Knowing this wire is signal, etc, isn't helping me connect the right four together. I could use some info like black-white/red, and so on.
Re: wiring for O2 sensor on on 94 p/u ? [Re: 95mini] #794594 03/07/07 04:50 PM
4Crawler Offline
Put the two prior replies together and you should have the answer, the first one shows the connections at the ECU and in the factory harness, the second one shows the O2 sensor connections.
If that does not help, I put them together for your convenience below:
Black - goes to ECU OX1 terminal = O2 Signal+ = Blue wire
Brown - ground = O2 Signal- = White wire
Pink/green stripe - goes to HT1 (heater) terminal on ECU = O2 Heater = Black wire
White/red stripe - +B (battery) from EFI main relay = O2 Heater = Black wire
Re: wiring for O2 sensor on on 94 p/u ? [Re: 4Crawler] #794595 03/07/07 06:55 PM
W
wildyota Offline OP
4crawler thank you for helping us less toyota educated folks. You have helped me out alot in the past with your informative posts!....thanks for making the O2 sensor wiring fool proof in your last post, it helped me... I've looked at your wiring diagrams, denso wiring diagrams, fsm and still had it goofed up.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6116 MB (Peak: 0.6981 MB) Data Comp: Off Server Time: 2026-06-07 01:36:05 UTC
