Re: Questions for future Gen 3 buy [Re: Lygriek] #794614 03/05/07 06:12 PM
cap510 Offline
The 2001 and 2002 XLS came with open difs front and rear, if you got the XLS w/Touring Package or the Limited you got the Mech LSD half of the Hybrid LSD/Locker that was available in the rest of the world. 2003 and later is definatly the way to go, having owned both I can tell you that the TC is very cool, and driving the 2002 with out was sometimes interesting especially with that touchy LSD
is the 01-02 LSD in the rear only? anything in the front on a limited?
Is the TC on the 03 and up for the front and rear? or how does it work?
Thanks! <img src="/forums/images/graemlins/cheers.gif" alt="" />
[b]94/95 Montero SR "rockcrawler"
Riding on 37" MTRs
Re: Questions for future Gen 3 buy [Re: cap510] #794615 03/05/07 06:22 PM
icysyrup Offline
Yes as far as I know the rear is the only axle with the LSD. (someone correct me if I am wrong) and the TC is for all 4 wheels...it senses wheel speed and slip and then applies braking to the slipping wheels which in turn sends torque to the opposite side wheel that has traction....Works off the ABS system which is why it tends to overheat once in a while <img src="/forums/images/graemlins/frown.gif" alt="" />
03 Montero XLS, OME 2"suspension lift,Full skid plates, Extended Diff/transfer breathers. 34 LTB's, Winch w/syn rope, Locked front/rear.
Re: Questions for future Gen 3 buy [Re: cap510] #794616 03/05/07 06:27 PM
Lygriek Offline
[quote
Thanks! <img src="/forums/images/graemlins/cheers.gif" alt="" /> [/quote]
Sorry, only in the Rear for the LSD on the 2001/2002, but the TC on the 2003 is all four wheels!
Very Cool Stuff. Uses the ABS system to apply the brakes on a wheel with no traction so the power goes to the other wheel thru the open diff, basically.
Takes a little getting used too though.
Lygriek, aka Michael
2003 Montero XLS GEN III, 285/75R16 Pro Comp Xtreme MT's
Ironman Springs/KYB Shocks. Custom Rocker Protection and Bumper.
Re: Questions for future Gen 3 buy [Re: Lygriek] #794617 03/05/07 07:01 PM
m_a_b Offline
I have an '02 Limited and can tell you that it also has the ABS traction control... I verified it on ice the other day! Also, the limited gives you a 5 gear automatic with the tiptronic system, which is VERY nice. Great vehicle - I just wish it had a V8 so I could tow big stuff with it.
'99 Isuzu Amigo S, 3.2L 4x4 softtop, 3" Calmini Lift, Indy4x Custom Bumpers & Sliders
Re: Questions for future Gen 3 buy [Re: m_a_b] #794618 03/05/07 07:21 PM
W
Winston Offline
I love my '03 Gen III. The 03 has "stability control" which includes traction control. The prior years might have had "traction control" which is a less sophisticated animal.
The drive line and suspension is different from '03 on. The early models had a problem with a "clunking" rear end. Of course, the 3.8L vs the 3.5 on the earlier models. Other than that, not much difference.
'90 Montero XLS (Sold, sadly)
'95 Montero LS 160k
'03 Montero Limited 30k
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6105 MB (Peak: 0.6921 MB) Data Comp: Off Server Time: 2026-05-29 14:46:08 UTC
