Driveshaft Bolts; need lock washers? #794795 03/05/07 11:30 PM
J94_4runner Offline OP
Stupid question here, do the driveshaft bolts need lock washers? I know stock they have them. Does it matter which side they are on? the Nut or the bolt side?
www.celicasupra.com
Re: Driveshaft Bolts; need lock washers? [Re: J94_4runner] #794796 03/05/07 11:58 PM
4Crawler Offline
If I use washers there, I put them on the nut side. I think one of my flanges is too thick to use the washers, so just use the nuts as-is.
Re: Driveshaft Bolts; need lock washers? [Re: 4Crawler] #794797 03/06/07 12:03 AM
10-4. that's what I thought. thanks roger.
www.celicasupra.com
Re: Driveshaft Bolts; need lock washers? [Re: 4Crawler] #794798 03/10/07 06:47 AM
KiwiCowboy Offline
On the rear flange I put the lock washer on the bolt head side so I can put it in from the front side and then the nut and bolt clear the seal better. Use locktite on the hex nut.
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.011s) Memory: 0.6006 MB (Peak: 0.6556 MB) Data Comp: Off Server Time: 2026-07-14 08:17:46 UTC
