Page 3 of 4 1 2 3 4
Re: rear breakes stuck.. [Re: 4Crawler] #794872 03/07/07 05:58 AM
d_a_r_kstar Offline OP
that seems like a big job lol there isn't a easier way to remove it than pulling out the whole axle shaft.. if i beat it with a hammer will that break the ebreak clamp thats stuck to it..
Re: rear breakes stuck.. [Re: d_a_r_kstar] #794873 03/07/07 06:45 AM
OOP'S Offline
Yeah it is a big job, takes all of maybe 5-10 minutes to pull an axle. That is counting jacking it up and taking the tire off. You can dink around trying with a hammer or being a contortionist trying to loosen the star wheel or do it the way we have suggested and make it easier on yourself. I know what I would do, pull the axles, but what do I know, I have only been turning wrenches for fifty-four years!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: rear breakes stuck.. [Re: OOP'S] #794874 03/07/07 06:53 AM
to pull the axle do i have to mess around with the rear diff?? or how does it come out?
Re: rear breakes stuck.. [Re: d_a_r_kstar] #794875 03/07/07 02:56 PM
BRreddog Offline
Before you go Nuclear on anything, get a can of AeroKroil, pentrating oil spray, and spray a shot on each stud where it comes through the drum. Then gently tap with a hammer on the side of the drum as you pull on it with the other hand. Alternatively use the two bolts in the front of the drum to force it off. Make sure to turn the bolts evenly, say a half a turn each, so you don't get the drum cocked where it binds. Never lost a case yet!
'86 22R Bored .080", Stroked 5.5mm, LC header, Downey 2.25" SS exhaust, 33" SST Coopers, 4W disk brakes, T-Case brake, PRP Seats
Re: rear breakes stuck.. [Re: d_a_r_kstar] #794876 03/07/07 03:14 PM
OOP'S Offline
Nope.
To pull the third out, after you pull the axles out
Drain the oil
Take the four bolts off the D-shaft
Remove the nuts on the third
Remove the third.
David Fritzsche
Roseville, CA
Re: rear breakes stuck.. [Re: d_a_r_kstar] #794877 03/07/07 03:29 PM
grandeyota Offline
Just undo the brake lines and parking brake, then the 4 bolts(red arrow)on the axle and pull it out of the diff.
No reason to mess with the 3rd. Goes back in the same way.
Thats pretty much it.
Fur clog in the sausage grinder
Re: rear breakes stuck.. [Re: grandeyota] #794878 03/07/07 08:29 PM
half_fast Offline
Slide hammer/steering wheel puller/pully puller...... all can be rigged to pull the brake hub off. Question is, is it really stuck, or just hung up on the brake shoes by the wear ridge? A couple of good slams by a sledge might break it free... or if it happens to break the hub, chances are it was worn enough it needed replaced anyhow. If that dont work....try a bigger hammer.
The only problem Ive ever had with brakes locking up was a master cylinder problem.... it would build pressure on a peddle press, but would not release it when taking my foot off the brake peddle. This problem occured on the trail and was a real bear to diagnose and deal with. Ive since added a master cylinder to my spare parts bin.
Michael J. Carsner proud driver of "Aint Pretty"
37 boggers, 571 gears, Detroit+Lock-Rights, 20R stage 1 LC Engineering head on 22R motor.
MUD!!! Its whats for dinner!!
Re: rear breakes stuck.. [Re: grandeyota] #794879 03/08/07 02:43 AM
oh sweet thanks.. do i drain the oil out of the rear diff??? and do i gotta bleed the breaks again after i put it back together?
Re: rear breakes stuck.. [Re: d_a_r_kstar] #794880 03/08/07 03:38 AM
OOP'S Offline
No,if you are not pulling the third member and yes if you are pulling the axles. All four wheels and the LSPV.!!!!!
David Fritzsche
Roseville, CA
Re: rear breakes stuck.. [Re: OOP'S] #794881 03/08/07 03:47 AM
lspv?
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6401 MB (Peak: 0.7648 MB) Data Comp: Off Server Time: 2026-05-29 14:57:13 UTC
