Page 4 of 4 1 2 3 4
Re: rear breakes stuck.. [Re: grandeyota] #794882 03/08/07 03:50 AM
d_a_r_kstar Offline OP
to pull the axle do i have to mess around with the rear diff?? or how does it come out?
Just undo the brake lines and parking brake, then the 4 bolts(red arrow)on the axle and pull it out of the diff.
No reason to mess with the 3rd. Goes back in the same way.
Thats pretty much it.
where am i draining the oil from if i do this?? the rear diff??and do i pull the break line that the fluid runs thru?
Re: rear breakes stuck.. [Re: d_a_r_kstar] #794883 03/08/07 04:15 AM
4Crawler Offline
No need to drain oil, none will come out if you are on fairly level ground. Disconnect and plug the brake hardline (you'll need to bleed the brakes afterwards) and pull the pin on the e-brake cable to disconnect it from the e-brake lever.
Re: rear breakes stuck.. [Re: d_a_r_kstar] #794884 03/08/07 06:04 AM
OOP'S Offline
lspv?
It is a valve that is on the right side of the frame. It is above the rear-end. There is supposed to be a rod connecting it to the rear-end. LSPV stands for Load Sensing Proportioning Valve; it changes the bias on the braking system depending on the load in the back.
The correct bleeding procedure is;
DriverÆs side rear
Passenger side rear
Passenger side front
DriverÆs side front
LSPV- Load Sensing Proportioning Valve
Suggestion for you, get a repair manual
Question to you, what year truck/runner do you have?
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6034 MB (Peak: 0.6735 MB) Data Comp: Off Server Time: 2026-05-27 17:00:50 UTC
