4RUINNER GAS MILEAGE #794948 03/06/07 07:03 AM
dirtybikez Offline OP
I got a quick question about some other 4runner gas mileage readings, i have an 88 4runner sr5 v/6 with 265/16in tires with a flowmaster and im getting about 14 mpg in the city i know thats s#!? for a 3.0 liter v/6. my 2500 mega-cab dodge gets 16 in the city and that has a 5.9 liter diesel. thanks if you got any reponse
Re: 4RUINNER GAS MILEAGE [Re: dirtybikez] #794949 03/06/07 08:44 AM
Snowtoy Offline
Is it an auto?, if so that is about normal.
If it is a 5-spd, it should do better than that with stock tires. It may be time for a completet tune-up.
Re: 4RUINNER GAS MILEAGE [Re: Snowtoy] #794950 03/06/07 08:51 AM
kewlynx Offline
That's what I'm thinking too; tuneup time!
**ubi apis- ibi salus**
Re: 4RUINNER GAS MILEAGE [Re: dirtybikez] #794951 03/06/07 03:40 PM
bkg Offline
Your tires are taller than stock; don't forget to compensate for that (I think the 265's are about 10% bigger than the 235's that the truck came with)...
So that would put you into the 15.5-16mpg range for city. Nothing unusual about that, especially if it's an auto.
EDIT: need to consider section width, ratio and wheel size in this math, which I did not do. My bad.
Brian K. Gallus
Re: 4RUINNER GAS MILEAGE [Re: bkg] #794952 03/07/07 12:38 AM
car is a 5 speed and a full tune up done 6 months ago
Re: 4RUINNER GAS MILEAGE [Re: dirtybikez] #794953 03/07/07 01:51 AM
Snowtoy Offline
I missed the tire size being 265's, I think 225's are stock. BKG is right about the mpg being closer to 15.5-16mpg's.
Did the full tuneup include cleaning the injectors, a new fuel filter and a compression check/valve adjustment?
How old is teh O2 sensor, from what I understand the OBD1 sensors get lazy with age and tend to run rich.
Was the truck getting better mileage before, or is it a new rig for you?
What pressure do you run in the tires?
Re: 4RUINNER GAS MILEAGE [Re: Snowtoy] #794954 03/07/07 06:44 AM
Car was purchased from friend who did basic tune-up like plug, wires, water lines, valve adjustment, and a few other small things except for the injectors and fuel filter but running injector cleaner through system right now to hopefully help a little
Fuel filter, o2 sensor, OBD1 sensors i no idea when replaced if replaced
i run about 50 psi on PRO-COMP ALL-TERRAINS
Re: 4RUINNER GAS MILEAGE [Re: dirtybikez] #794955 03/07/07 03:52 PM
bkg Offline
265/16's are ~32" tall... at 50 lbs, possibly closer to 33, even. That's closer to 20% larger than stock.
Brian K. Gallus
Re: 4RUINNER GAS MILEAGE [Re: dirtybikez] #794956 03/08/07 02:56 AM
Snowtoy Offline
Running injector cleaner really doesn't do much if the injectors are dirty. I used to run the stuff through mine, and when I had them rebuilt the tech said they were filthy. You could lose some % mpg if the injectors aren't atomizing the fuel, though might not be enough to warrant pulling them and having them rebuilt.
With the age of the truck and no idea when/if the O2 sensor was replaced it would be a good idea to replace it, shoudl run somewhere between $50 and $100 for a denso, the dealer charges a little more.
However after you adjust for the difference in tire size(if you weren't before), youir city mpg isn't that bad. You could improve it some by changing your driving style. Try to keep the rig moving as much as possible, i.e. don't gas up to a stop, coast as much as you can. Don't do jack rabbit take-offs, since Toyotas are heavy rigs(to engines), you can waste a lot of fuel through heavy acceleration from stops. Also keep the tranny in a gear that keeps your rpms up around 3k(shift at about 4k), this is the beginning of the 3.0 power band, running below this point is wasting fuel.
Re: 4RUINNER GAS MILEAGE [Re: Snowtoy] #794957 03/08/07 04:10 PM
TimsToyo Offline
Quick tire calculation:
New tire size / old tire size = % of Difference
Example;
265 / 225 = 1.17777 or a 17.8% increase in tire size.
'86 Toyo 4wd
'04 600RR
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6396 MB (Peak: 0.7645 MB) Data Comp: Off Server Time: 2026-06-07 06:02:18 UTC
