rear wheel wobble? #794976 03/06/07 12:31 PM
bigjeep1980 Offline OP
Just picked up a 1993 YJ...My wife followed me home and said that the rear wheel on the passanger side was wobbling.The axle and tracking bar look o.k. What would be the obvious to look for. Appreciate the help. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: rear wheel wobble? [Re: bigjeep1980] #794977 03/06/07 01:43 PM
O
oldgreen Offline
Go with the obvious first, check the lug nuts. Then try the spare maybe the rim took a hit and is bent.
84 CJ7 304 HEI 35 BFG,s rear dana 60 with detroit locker,Viar compressor, fibreglass body, 2 1/2 spring lift, TF999auto, Warn 8000 winch, Plus a cool little trailer on 35,s. JEEP stands for just empty every pocket
Re: rear wheel wobble? [Re: oldgreen] #794978 03/06/07 02:10 PM
Thanks old green, The lugs seem fine...will pull the wheel in a bit... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: rear wheel wobble? [Re: bigjeep1980] #794979 03/06/07 02:40 PM
DBL_DTY97TJ Offline
Could you feel it while driving? If not could it have been an optical illusion created by something on the tire, or on part of teh tire? Even loose lugnuts you will feel by about 35-40mph in my experience.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: rear wheel wobble? [Re: DBL_DTY97TJ] #794980 03/06/07 04:39 PM
BigJim Offline
Most likely the wheel itself is bent.. I have seen tires with the tread on crooked! making the thing look wobbly.. But usually it is the wheel.
Let HER drive it and YOU look at it!
Re: rear wheel wobble? [Re: BigJim] #794981 03/06/07 05:05 PM
I could not feel it at speed up to 40 or so. I am going to pull it off and put the spare on. We will see if that is the gremlin...Thanks guys... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: rear wheel wobble? [Re: bigjeep1980] #794982 03/06/07 05:39 PM
The sare is locked on and I dont have the key!!!
Can It be cut off easily??? <img src="/forums/images/graemlins/evil.gif" alt="" />
Re: rear wheel wobble? [Re: bigjeep1980] #794983 03/06/07 06:48 PM
jstritec Offline
Is it one of those special lugs that takes a key?
I've gotten those off with a big set of channylocks before.
Josh
80 CJ-7.
It runs
Re: rear wheel wobble? [Re: bigjeep1980] #794984 03/06/07 06:49 PM
Problem solved...I used a cut off wheel to remove the lock...The tire itself was very deformed and warped. Could not tell when on the jeep but when off it rolled like a drunken sailor on shore leave! (apologies in advance to all sailors drunk or not!)
Thanks guys <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: rear wheel wobble? [Re: bigjeep1980] #794985 03/06/07 09:17 PM
BigJim Offline
The way to get a locker off of a wheel is to WHACK em straight in with a BFH and then the channel locks will take em ALL off...
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6359 MB (Peak: 0.7428 MB) Data Comp: Off Server Time: 2026-10-21 22:04:23 UTC
