Aisin Hub ID.
#795031
03/06/07 07:52 PM
I have a pair of Aisin manual hubs that I found at a pick n' pull and I'm not sure what they are for. I found them nicely bagged up in the back of a mid 90's 4Runner but the body of the hub is 1/2" shorter that the Aisin hubs on my '88 IFS. What do you all think?
Re: Aisin Hub ID.
[Re: thorn4run]
#795032
03/06/07 08:35 PM
count splines on hub gear. if its 30 is for a solid axle 79-85. if its 27 its IFS, but you said they are shorter. IIRC some other vehicles came with aisin hubs too?
1989 TOYOTA PICKUP 4"trailmaster, 3" Body Lift 8,000 lb warn winch, q-78 tsl super swampers
Re: Aisin Hub ID.
[Re: maxxis85]
#795033
03/06/07 09:01 PM
They also came on Sammy's
"Serenity through Sobriety"
Re: Aisin Hub ID.
[Re: OOP'S]
#795034
03/06/07 09:45 PM
Re: Aisin Hub ID.
[Re: Adam F]
#795035
03/06/07 10:34 PM
OK, I've counted the splines and came up with 26. The body measures 1 and 3/8" from the mounting surface to the back of the dial cap. It uses the cone plit retainers and the mounting holes measure 3 1/2" across. I found a pic. of a Tacoma hub and it looks shorter that earlier Toyota hubs. http://www.sonoransteel.com/aisin_manual_hubs.html
