Aisin Hub ID. #795031 03/06/07 07:52 PM
thorn4run Offline OP
I have a pair of Aisin manual hubs that I found at a pick n' pull and I'm not sure what they are for. I found them nicely bagged up in the back of a mid 90's 4Runner but the body of the hub is 1/2" shorter that the Aisin hubs on my '88 IFS. What do you all think?
Re: Aisin Hub ID. [Re: thorn4run] #795032 03/06/07 08:35 PM
maxxis85 Offline
count splines on hub gear. if its 30 is for a solid axle 79-85. if its 27 its IFS, but you said they are shorter. IIRC some other vehicles came with aisin hubs too?
1989 TOYOTA PICKUP 4"trailmaster, 3" Body Lift 8,000 lb warn winch, q-78 tsl super swampers
Re: Aisin Hub ID. [Re: maxxis85] #795033 03/06/07 09:01 PM
OOP'S Offline
They also came on Sammy's
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Aisin Hub ID. [Re: OOP'S] #795034 03/06/07 09:45 PM
Adam F Offline
97 4R, stock, daily driver
Re: Aisin Hub ID. [Re: Adam F] #795035 03/06/07 10:34 PM
OK, I've counted the splines and came up with 26. The body measures 1 and 3/8" from the mounting surface to the back of the dial cap. It uses the cone plit retainers and the mounting holes measure 3 1/2" across. I found a pic. of a Tacoma hub and it looks shorter that earlier Toyota hubs.
http://www.sonoransteel.com/aisin_manual_hubs.html
Re: Aisin Hub ID. [Re: thorn4run] #795036 03/08/07 05:31 PM
OK, I think I've got it figured out. They must be from a 1995.5-2004 Tacoma. That's what I've gathered from this site ( http://www.sonoransteel.com/junk_yard_manual_hubs.html ) I also take it that these hubs must not be very common.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6097 MB (Peak: 0.6795 MB) Data Comp: Off Server Time: 2026-10-21 22:03:22 UTC
