2000 Trooper tranny ? #795184 03/07/07 04:45 PM
fourwd1 Offline OP
A few weeks ago the tranny gear indicator on the dash started acting up. Mostly showed 3 no matter what gear I was in. Eventually would move to D (the actual gear I was in). Sometimes it would just jump all around, stop, then jump around ...
Then one day the tranny seemed to be shifting back and forth between D and 3, but I wasn't sure because the tach didn't seem to change with it.
This morn the tranny stayed in 3 the whole way to work (so did the dash indicator) even tho the shifter was in D.
Anyone seen this before?
The tranny ECM maybe?
I'm searching my FSM CD to see if the dash indicator is driven by the tranny ECM or the shifter switch, as it may be a clue.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: 2000 Trooper tranny ? [Re: fourwd1] #795185 03/07/07 05:14 PM
Richard Saylor Offline
First thing I would do is check the shifter linkages. Maybe something is bent/worn and needs to be corrected. That's the first thing that I'd do because it's the simplest. Next is I'd check the fluid level.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: 2000 Trooper tranny ? [Re: fourwd1] #795186 03/07/07 06:11 PM
fourwd1 Offline OP
The shifter is not moving nor is there any play.
It's the dash electronic gear display that jumps around like it has a mind of it's own.
Re: 2000 Trooper tranny ? [Re: fourwd1] #795187 03/08/07 05:17 AM
trooperbc Offline
i would suspect the mode switch on the transmission. sometimes also called gear selector sensor or a combination of the two. essentially it tells the trans computer what gear you have selected with the shifter. if the switch sends the wrong info to the trans computer, it sends the wrong directions to the electronic's part of the transmission, while the mechanical gear selector has the trans doing things for the gear selected.
anyway, confusion reigns, and there are several symptoms inclulding the dash gear selector lights going haywire.
people take them off and clean them with some good results. it didn't work for me (it was just worn). and i ended up replacing it with new. if you are doing the work yourself, it might be worth the experience as it was for me. if you pay someone else and you have tested it, replacing probably is the better option.
here's a thread of mine that has a lot links on this that may help you decide.
http://www.4x4wire.com/forums/showf...902938&fpart=&PHPSESSID=
1992 sohc trooper 3.2l v6 automatic . . . as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Re: 2000 Trooper tranny ? [Re: trooperbc] #795188 03/09/07 04:28 PM
fourwd1 Offline OP
That's exactly the conclusion I've come to, especially after I looked under and saw the switch was outside the vehicle exposed to the elements.
Going to tear into it tommorow.
Re: 2000 Trooper tranny ? [Re: fourwd1] #795189 03/09/07 04:43 PM
fourwd1 Offline OP
And thanks for the link to your thread, that stuff will come in handy.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6154 MB (Peak: 0.7020 MB) Data Comp: Off Server Time: 2026-05-27 21:20:47 UTC
