Re: YJ Axle Options [Re: BigJim] #795252 03/11/07 06:58 AM
ChrisYJ Offline OP
Yes, cast iron rings. There was about a 2 inch long piece broken out between the 1st and 2nd ring. It was captive between the rings, but riding up and down loose from the rest of the piston. I bought a new piston today and the bore still looks perfect surprisingly so I'm just going to de-glaze it and go.
Re: YJ Axle Options [Re: ChrisYJ] #795253 03/11/07 06:01 PM
BigJim Offline
It is surprising to find pieces of piston in the pan when you open her up. If the thing has blown up is one thing but if it is running Ok is something else. I have found bits and pieces of pistons in pans quite a few times. For some reason I have found the "tails" of pistons several times in otherwise Ok engine pans. I just put the pan back on and let em run.
I never saw a floating piece of piston like you describe though. Don't deglaze too much deglazing is WEAR too.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.5929 MB (Peak: 0.6575 MB) Data Comp: Off Server Time: 2026-06-09 23:06:17 UTC
