A thought I'm Toying with...... 84 Runner #795343 03/08/07 10:38 AM
trcdrunner Offline OP
Been on a debate with myself.....
My 84 Runner (22R) is getting a lil rough.
Floor boards have a few holes and body is seperating, had a lot of rust - I bondo'd a few years ago - Rig is trail rig, glass is cracked....
Well I have an 87 Runner that has a great bod firewall back - no cracks in the glass....
How much trouble would swapping the bodies be? the 87 is an auto the 84 is a 5 speed - the 87 is minus the motor and tranny..... so the 84 would stay - I know that tunnel may need trimming (fine - I want duals in the future) and in the process a 2" body lift.
I would need to keep the 84 front - 87 was in an accident so all that is shot.... then there is the pedals.
Should I swap bodies or weld/pop rivit steel into the floors and be done and work with I got???????????
aka FireNIce
84 Runner 33" Swamper LTB, 4.30's, Spool in Rear, Lock-Right soon in front exo-caged, 4" lift.
TRCD Toys Web Site
TRCD Toys Apperal
Re: A thought I'm Toying with...... 84 Runner [Re: trcdrunner] #795344 03/08/07 03:27 PM
TimsToyo Offline
It's hard for us to say without seeing how bad the rust holes really are. I'd say if you have to replace more than 25% of the body to repair the rust holes it'd be better to use another cab and bed from the donor.
'86 Toyo 4wd
'04 600RR
Re: A thought I'm Toying with...... 84 Runner [Re: TimsToyo] #795345 03/08/07 09:31 PM
RatLabGuy Offline
Maybe I'm missing something.... but I wonder if it's be easier to take the drivedrain and front end from the '84 and put into the '87.
The tunnel part of the bodies are the same, only different really is the floor pan behind it wher ethe holes for the shifters are. Oh and like you said the firewall for the clutch pedal, too.
Question Reality.
Re: A thought I'm Toying with...... 84 Runner [Re: trcdrunner] #795346 03/08/07 10:31 PM
Adam F Offline
I'd just chop it up and tube it out. If I had the money thats exactly what I'd do to mine
97 4R, stock, daily driver
Re: A thought I'm Toying with...... 84 Runner [Re: Adam F] #795347 03/08/07 11:42 PM
thanks for the inputs... keep em coming
hhhmmmm the cut up not a bad idea, but i wanted to keep it looking like a runner....
thought about building the 87 BUT - then i need to SAS it.....
my 84 frame is in real good shape.......
aka FireNIce
TRCD Toys Web Site
TRCD Toys Apperal
Re: A thought I'm Toying with...... 84 Runner [Re: trcdrunner] #795348 03/09/07 12:48 AM
eightyeight Offline
its really not hard to swap bodies.
im kicking myself for fixing my pickup cab instead of swapping on another one. if its bad you will most likely spend way more time in body work than body swapping.
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: A thought I'm Toying with...... 84 Runner [Re: eightyeight] #795349 03/09/07 01:17 AM
CJM Offline
I agree ... If you have a good body avaliable , swap it .. in years to come , you'll be glad you did .
83 Trekker SR5
NEW Trekker forum
Re: A thought I'm Toying with...... 84 Runner [Re: CJM] #795350 03/09/07 05:37 AM
RatLabGuy Offline
Not intended as hijack, maybe relevant....
If you do something like this and swap a complete body, which title stays with it? The body or frame?
Question Reality.
Re: A thought I'm Toying with...... 84 Runner [Re: RatLabGuy] #795351 03/09/07 05:41 AM
kewlynx Offline
I would think you'd have to do a salvage title or something of the like. Your state DMV would know, as I'm sure this varies.
**ubi apis- ibi salus**
Re: A thought I'm Toying with...... 84 Runner [Re: kewlynx] #795352 03/09/07 06:15 AM
A
Andy87 Offline
Keep the '84 title and use the '84 dash, or rivet the '84 dash vin tag to the '87 dash. Oh, and I also vote for swapping the bodies...
'87 Xtra Cab, 4wd, 22r, 5spd
'92 Xtra Cab, 4wd, 2L-TE diesel swap, 5spd
http://toyotadiesel.com/forums/showthread.php?t=2502
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6412 MB (Peak: 0.7603 MB) Data Comp: Off Server Time: 2026-05-29 16:01:29 UTC
