Muffler or O2 Sensor Which First? #795362 03/08/07 03:16 PM
A
ADAMan Offline OP
Along with my other problems, I am in dire need of a muffler, mine looks as if it got shot with buckshot. I do not know thee history of my O2 sensor either. My truck has 188K. Trying to boost fuel milage, I am getting 14-16 and just get it running good. My check engine light is on for my O2 sensor. Should I replace muffler first, and see if that corrects my O2 sensor reading, (read where a certain amount of back pressure is needed), and with ALL the hole I know I am not getting ANY backpressure. I priced a muffler and tailpipe assembly at Advance Auto for $100. Does anyone know of a cheaper or better quality for the money source for muffler/tailpipe assemblies?
Re: Muffler or O2 Sensor Which First? [Re: ADAMan] #795363 03/08/07 03:21 PM
TimsToyo Offline
Without question replace the O2 sensor. The muffler won't help with the poor performance and bad gas mileage nearly as much as a fully functioning O2 sensor.
When you get ready for a muffler see if that shop is still open in Prattville across from the Old Larry Puckett Chevy dealership on US31. I used then in the past and they did good custom work for cheap. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PS I'm assuming you're in Montgomery, Al. ??
'86 Toyo 4wd
'04 600RR
Re: Muffler or O2 Sensor Which First? [Re: TimsToyo] #795364 03/08/07 03:26 PM
A
ADAMan Offline OP
Yes I am in MGM, AL. I was just gonna buy one, its only 2 bolts to the cat. conv with a gasket. How hard can it be?
Re: Muffler or O2 Sensor Which First? [Re: ADAMan] #795365 03/08/07 04:01 PM
TimsToyo Offline
Have you replaced the CAT? If not it needs to go as soon as you get the fuel mapping fixed.
'86 Toyo 4wd
'04 600RR
Re: Muffler or O2 Sensor Which First? [Re: TimsToyo] #795366 03/09/07 02:27 AM
A
ADAMan Offline OP
Have not replaced the cat. One Benjamin Franklin at a time. Gonna put in the O2 tomorrow. Will keep posted.
Re: Muffler or O2 Sensor Which First? [Re: TimsToyo] #795367 03/09/07 04:50 AM
yotaman7 Offline
x2
"4X4 in upper case is $X$" Quoted from http://4crawler.com/4Runner.shtml
'00 tacoma 4WD---Sold to Toyota
'93 pickup 2WD
'85 pickup 4WD
Re: Muffler or O2 Sensor Which First? [Re: yotaman7] #795368 03/11/07 01:10 AM
TimsToyo Offline
O2
CAT
Then the muffler
or both at the same time.
'86 Toyo 4wd
'04 600RR
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6114 MB (Peak: 0.6892 MB) Data Comp: Off Server Time: 2026-07-09 17:40:17 UTC
