lacking power #795646 03/09/07 07:18 AM
my88toy4 Offline OP
88 4runner 22RE lacking power, I suspect cat converter???
any ideas ? Is there such thing as an aftermarket cat that outperforms stock without affecting O2 sensor ? I'm not really concerned about emissions, just want my power back!
Help!!
Re: lacking power [Re: my88toy4] #795647 03/09/07 07:34 AM
kewlynx Offline
When's the last time you did a full tuneup and check the TPS setup?
**ubi apis- ibi salus**
Re: lacking power [Re: my88toy4] #795648 03/09/07 03:54 PM
cktoy Offline
get rid of the cat,new plugs,wires pcv valve dist cap rotor button fuel filter ,adjust valves. add a can of "sea foam" that revived mine tremendously
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: lacking power [Re: cktoy] #795649 03/09/07 06:12 PM
my88toy4 Offline OP
have recent tune-up, fuel filter,PCV, valve adjustment,air filter,etc. helped a little but still lacking thus my suspecting exhaust issue,it's pretty new from cat back. Will it run w/o cat and NOT create O2 sensor performance probs ?
Re: lacking power [Re: kewlynx] #795650 03/09/07 06:14 PM
my88toy4 Offline OP
stupid question, I am new to these Toys, what's TPS???
Re: lacking power [Re: my88toy4] #795651 03/09/07 06:23 PM
cktoy Offline
mine is carburated and it is fine w/o the cat ,I'm not sure about efi.It can be done but you might have to make some modifications.I think tps is throttle position sensor,but you better check with one of the efi guys to be sure.search the cat topic on here Im sure there has been a thread on it.
oh what a feeling:
84 supra yard art
Re: lacking power [Re: my88toy4] #795652 03/09/07 06:24 PM
cktoy Offline
mine is carburated and it is fine w/o the cat ,I'm not sure about efi.It can be done but you might have to make some modifications.I think tps is throttle position sensor,but you better check with one of the efi guys to be sure.search the cat topic on here Im sure there has been a thread on it. oh yeah check timing
oh what a feeling:
84 supra yard art
Re: lacking power [Re: cktoy] #795653 03/09/07 07:53 PM
IceBlueT Offline
i just put a new cat on my truck, and it runs much better. i was actually pretty suprised. i would definetly try putting a new cat on. it cant hurt.
formerly 277000_yota
Old enough to know better, but still to damn arrogant to care...
]www.cardomain.com/ride/2614269
'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P)
'98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
Re: lacking power [Re: IceBlueT] #795654 03/09/07 08:26 PM
my88toy4 Offline OP
I've never had trouble removing cat from carbed vehicles but sometime creates issues with fuel injected,since I am new to toys, figured I'd be better off asking before I experiment.
Where did you get your hi/flow cat ???
Re: lacking power [Re: my88toy4] #795655 03/10/07 02:35 AM
canuck Offline
Had a similar problem with 87 22re. Did all the tuneup etc then took the cat off and noticed it was all plugged up with carbon. Left the cat off and installed a cherry bomb. What a difference. After all this I still noticed it running rich. Did a TPS and timing adjustment. It even got better.
Keep the Shiney Side up. Support our troops.
PHP: 7.4.33 Page Time: 0.024s Queries: 16 (0.019s) Memory: 0.6371 MB (Peak: 0.7602 MB) Data Comp: Off Server Time: 2026-11-03 03:01:03 UTC
