Engine Temp Guage Actin Weird #795732 03/10/07 12:10 AM
JWaldz Offline OP
I just noticed the other day that my temp guage is actin up. It works but it goes back and forth between about 170 and 220. It doesn't over heat or anything and drives fine, but it just goes back and forth just drivin down the road. I'm wondering if this is my temp guage goin bad or it's my actual temp thats bad? I'm dumbfounded...
'99 Toyota 4Runner Limited
RP Black Widow|8K HID Kit|265/75 Federal MT|Cobra NightWatch CB|Fosgate Sound
Re: Engine Temp Guage Actin Weird [Re: JWaldz] #795733 03/10/07 05:24 AM
BigJim Offline
If I had any doubts I'd change the sender and the thermostat!
Re: Engine Temp Guage Actin Weird [Re: JWaldz] #795734 03/10/07 08:19 AM
BobRowe Offline
I think the first most likely cause would be some corrosion on the hookup to the sender. The 2nd option would be to change the senser. The third option would be to change the thermostat.
Re: Engine Temp Guage Actin Weird [Re: BobRowe] #795735 03/12/07 09:41 PM
G
gus310 Offline
i think thats just a jeep thing. mine does it as well. my best guess is that the stock cooling system does a good job, but the thermostat opens at 190 or so, when it cools to less it shuts and the engine starts heating again. opens and cools, shuts and heats up, etc etc etc
Re: Engine Temp Guage Actin Weird [Re: gus310] #795736 03/12/07 11:34 PM
BigJim Offline
Gus he is talking about a 50* swing back and forth.. He should have a 195* thermostat in there and the temp should NEVER go below that when running. I have seen 220* in a wrangler before but it was under fairly hot circumstances. After reving the engine a bit the temp came back to 200* or so and all was well.
Big JIm
Ps Saturday Tony Stewart ran his race car for 40 1-1/2 mile laps at 180mph with a temp of 275* and spewing steam... Pulled something off of the radiator and the temp went back to 230* and he ran the rest of the race with no problem.
Re: Engine Temp Guage Actin Weird [Re: BigJim] #795737 03/13/07 04:24 PM
G
gus310 Offline
right, mine temp gauge goes from 210 to the line on either side being about 50* of difference. i never figured it was a big deal.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6115 MB (Peak: 0.6810 MB) Data Comp: Off Server Time: 2026-06-07 09:08:40 UTC
