Power mirror switch #795760 03/10/07 04:47 AM
DirkDoesDirt Offline OP
Looking for some advice on trying to find out why my power mirrow switch is not working. Its a 93 4runner. I have replaced the actual switch and that isn't the problem. I have looked for a fuse but can't find one that is listed for the mirrors. Everything else works on the door panel (switches) its just the mirrow one that quit.
Can anyone point me in the right direction of where to look? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Power mirror switch [Re: DirkDoesDirt] #795761 03/10/07 06:53 AM
kewlynx Offline
Check the wiring harness where it goes in from the body into the door; that's a high-wear area. Common in the older trucks/cars.
We also have a '93 FSM sticky'd in the early trucks section that would have the wiring diagram for ya.
**ubi apis- ibi salus**
Re: Power mirror switch [Re: kewlynx] #795762 03/10/07 07:41 AM
Thanks for the direction. The online manual was too old of a truck and it didn't mention power mirrors.
Will check out the door wires and report back. i'm thinking though that it is further inside the system like if there was a fuse or something but I can't find any listing for a fuse.
Re: Power mirror switch [Re: DirkDoesDirt] #795763 03/12/07 03:51 PM
RedRunner95 Offline
I took that whole thing apart and cleaned it out. Put a little grease on the ball joints and had it turning in no time.
Re: Power mirror switch [Re: RedRunner95] #795764 03/12/07 11:11 PM
You took the switch apart or the mirrors?
I tried a new switch and that didn't work and since both mirrors don't work, I assume its deeper. Did you find a fuse in this system?
I also checked where it goes in through the door but thats ok, so...
The manual says that there is a connector in the bottom left hand kick panel. Maybe corrosion in there? I'll look there next but the darn security box is up in there so will have to take that out first. Ugh.
anyone got anymore ideas?
Re: Power mirror switch [Re: DirkDoesDirt] #795765 03/13/07 03:26 AM
Kutter Offline
My 1995 4runner the mirror is powered off of the 7.5 amp Radio fuse. According to schematic.
Do you know if you have power at the switch? If both mirrors are failed then I would focus troublshooting on things common to both mirrors first.
See this link from the 1993 FSM stickied on the early truck forum. It is very detailed and includes troubleshooting tips/procedures.
http://personal.utulsa.edu/~nathan-buchanan/93fsm/bodyelectrical/9powermir.pdf
1995 4Runner Limited V6 3.4 Liter 5 Speed 4x4
1995 4Runner V6 Auto 2WD
Re: Power mirror switch [Re: Kutter] #795766 03/13/07 06:42 PM
Awesome, that looks like what I'm looking for. See that junction block, I'll bet is where my problem is. Now to get to it!!
Where did you find this sticky thing with the schematics?
Thanks again
Re: Power mirror switch [Re: DirkDoesDirt] #795767 03/13/07 07:26 PM
Kutter Offline
Re: Power mirror switch [Re: DirkDoesDirt] #795768 03/14/07 09:52 PM
RedRunner95 Offline
I took the mirror assembly apart and cleaned out the cob webs. It worked only briefly once i bought it but hadn't again for months. I checked the fuses and they were all good. So I checked the circuits and cleaned the crud off that too. But just some grease in the joints got it moving again.
Re: Power mirror switch [Re: RedRunner95] #795769 03/21/07 08:19 PM
Thanks everyone for their help. I bit the bullet and dug into the wiring betwen the door and the junction block. sure enough the positive and the ground wire had broken. Soldered back up and everything works.
Thanks again <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6343 MB (Peak: 0.7382 MB) Data Comp: Off Server Time: 2026-06-23 06:09:55 UTC
