main bearing chattering!!! #795850 03/10/07 05:13 PM
P
PhilipD412 Offline OP
At cold start up I am expericing one half to one second of bearing chatter <img src="/forums/images/graemlins/scared.gif" alt="" /> before it disappears. I have good oil pressure and use 30 weight oil. The motor is a plane 3.0 with 136.000 miles on it. Should I be worring alot about this or should i plan on a rebuild soon?
Thanks
phil
Re: main bearing chattering!!! [Re: PhilipD412] #795851 03/10/07 06:28 PM
engnbldr Offline
Thanks
phil
>>>*Can you describe that sound a bit better, please? The sound of a main bearing is typically a deep dull knock with lower than normal oil pressure....*EB
*Beats the he** outa me!....*LOL**...
Re: main bearing chattering!!! [Re: engnbldr] #795852 03/11/07 01:00 AM
TimsToyo Offline
Are you sure you're not hearing an idler pulley bearing or a valve rattle? I have something similar on cold start but I think mine is the idler pulley bearing.
'86 Toyo 4wd
'04 600RR
Re: main bearing chattering!!! [Re: TimsToyo] #795853 03/11/07 02:49 AM
canuck Offline
Relax, take a deep breath..... Its not the mains, In cold weather you get a rattle for a second until oil pressure builds up. Can't tell where your from but in my parts its -30c and I use 5w30 for oil in the winter.
Keep the Shiney Side up. Support our troops.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5985 MB (Peak: 0.6543 MB) Data Comp: Off Server Time: 2026-07-09 17:41:37 UTC
