Its not good to break valves.... #796002 03/11/07 04:32 AM
racerfan120 Offline OP
These are a couple pictures of what a broken valve can cause. This is mile 77 of a fresh motor. Unfortunatly we are thinking that the combo of the head and the cam caused it. The springs on this head, brand new from ebay, were 0.050 shoter than the stock springs, that and a .268 cam. Not only did it toast the piston and valve, it also put a crack in the block, and messed up the head. Fortuanatly the head can be fixed which is what we will do. Just thought I would show this to you all, kind of interesting I thought <img src="/forums/images/graemlins/wink.gif" alt="" />
[image]
]http://i131.photobucket.com/albums/p311/racerfan120/DSCF0325I.jpg[/image]
http://i131.photobucket.com/albums/p311/racerfan120/DSCF0324I.jpg
Re: Its not good to break valves.... [Re: racerfan120] #796003 03/11/07 07:10 AM
engnbldr Offline
>>>*There is almost enough information in the photos to diagnose the cause, not quite.
Note the piston markings, the valve stopped moving first, contacted the piston. Additional motion moved the valve further into the bore with successive strokes until the valve completely jammed.
It could be the guide was just too snug, or lacked adequate lube. It is possible the valve was drawn into the piston during installation, bending it it the cam was not perfectly in time at install.
But something jammed the valve first, or the valve released, that isn't the usual damage we see from a weak spring or from excess tension.
Coil binding normally results in failure at the keeper, although it could be that a valve lock slipped too since damage from pressing against the guide shows very high up the stem.
This indicates the valve was finally open much more than one would think possible if the locks stayed attached.
These heads will easily handle .450" lift and more if the installed spring length is 1.600" like it should be....*EB
*Beats the he** outa me!....*LOL**...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5888 MB (Peak: 0.6381 MB) Data Comp: Off Server Time: 2026-10-21 20:42:58 UTC
